View Full Version : Oil pan remove 48 Champion?
CHAMP
04-20-2006, 08:15 PM
Shop Manual says remove engine to replace rod bearings? Anybody know any short-cuts? Thanks! Champ:(
JDP
04-21-2006, 12:07 AM
Yes, pull the engine. It's quicker than what you'd have to do trying to drop the pan in the car. You can pull a flathead six in about 2 hours tops.
64 R2 4 speed Challenger
63 R2 4 speed GT Hawk
63 Avanti
54 3R Pickup
04-21-2006, 12:51 PM
I won't say it COULDN'T be done IN the car. But I sure wouldn't want to try![}:)]
CHAMP
04-21-2006, 03:30 PM
Thanks JDP AND Mr. Biggs, I'm not 100% sure that it is rod bearing knock! Champ:(
N8N
04-21-2006, 03:37 PM
Maybe I am missing something. couldn't you undo the engine mounts, jack the engine up and shove blocks of wood under them, then drop the pan and roll new shells in in the car?
BTDT... but not in a Studebaker...
62 Daytona hardtop
JDP
04-21-2006, 05:03 PM
N8 not enough room to do that. BTW, make sure it's a rod knock, piston slap is not unusual on a Champion.
63 Avanti
54 3R Pickup
CHAMP
04-21-2006, 05:29 PM
Would piston slap be caused by a worn wrist-pin? I seem to remember that they would last a long time if driven normaly? The engine was rebuit about 4,000 miles ago by previous owner. Thanks Champ
04-21-2006, 07:10 PM
Describe the nature of the knock. Only hot, cold, both? Under load - no load, acceleration - deceleration. Dull thud, sharp clack?[:I]
Oh - and what's the oil pressure like?
unclemiltie
04-21-2006, 09:53 PM
I think the 48 is like my 47 Champ, the front suspension is the transverse spring which sort of makes the pan real hard to remove in the car. It is easier to pull the engine than it is to pull that spring
Milt
JDP
04-21-2006, 10:45 PM
Traverse spring AND a front sump pan, pull the engine.
63 Avanti
54 3R Pickup
CHAMP
No noise till it warms up. Noise starts at 12 to 15 mph. in 1st gear, 20 to 25 mph in 2nd gear, 42 to 45 mph 3rd gear and a little over 55mph in o.d. Under load yes steady speed yes acceleration yes deceleration no noise. More like a rattle than a dull thud or sharp clack. oil pressure is over 40 cold, a little over 30 at highway speed, and over 20 at idle. Thanks again Champ
CHAMP
05-09-2006, 08:58 AM
Good news! The noise in my engine was the water pump! Also found a bad front motor mount. I think the bad mount was causing the noise to resonate and make the noise sound different than what it was. Champ[8D]
