View Full Version : Wheel Problems
MacMyers
04-20-2006, 07:23 PM
Greetings. Does anyone have any super duper sure fire tips for getting a wheel lock off when you don't have the key? I'm thinking Sledge Hammer and big chisel.... but there is a small possibility that that (can you use two thats like that?) might damage the lug.
Fire, Magic? Give up?
Thanks,
Mac
Proud Owner of the one and only 1963 BEND OVER
POOP HAWK and the 1966 Messtang!
04-20-2006, 07:43 PM
I'm thinkin' blue wrench (but I've never tried it before)
jjones
04-20-2006, 08:10 PM
If you have the kind where the key makes the hex rotate free, you can hit it square on with a BFH. The only one I had experience with, that split the outer shell and I was able to grip the nut with visegrips and take it off. Don't know about the other kind but I imagine some of the kids in my neighborhood could do it in about 30 seconds. They probably wouldn't tell me how, though. Hope this helps and good luck
jj
Pat Skelly
04-20-2006, 08:15 PM
Try a nut splitter.
Pat Skelly
62 GT Hawk
53 Studillac
37 Dictator Coupe
studegary
04-20-2006, 09:11 PM
If it is one of the modern type, ask around to borrow wheel lock keys from your friends. They don't manufacture a lot of combinations. You may get lucky. Perhaps if you post a picture of what you have/need, someone here could come up with a key that they could send to you on loan.
Of course, the obvious first thing to do is to search through the car for the key. I have found them in places like; glove compartment, ash tray, spare wheel well, fastened to lug wrench.
1959 DeLuxe pickup (restomod)
N8N
04-20-2006, 09:40 PM
if all else fails there are sockets that you can drive over the nut that will cut little grooves in it and allow the socket to grip on the formerly smooth outer surface of the nut. I know Snap-On makes them; not sure if there's a Craftsman-priced version or not.
62 Daytona hardtop
MacMyers
04-20-2006, 11:16 PM
Thanks guys... I'll try some of that. It's one of the ones that uses the oddly shaped ring thing that has a matching oddly shaped lip key. I'm going to try to find a nutsplitter/socket cutter and wail on the SOB.
BobPalma
04-21-2006, 09:50 AM
Mac: Do you know anybody at a tire shop or general garage in the area? If so, they likely have one of several kits marketed for the trade with heavy "universal" sockets that you pound on the wheel lock nut (pound hard!). They grip the nut with sheer friction and force. Then you unscrew the nut with a socket wrench placed on the universal socket you just hammered on. It usually ruins the nut coming off, but the object is to get the nut off and if you don't have the key for it anyway, who cares if it is ruined, so long as it is OFF!
Of course, you can buy those kits commercially, but they are expensive. Better to buy your buddy at the garage a six-pack of beer or a dozen doughnuts and "rent" his. ;) BP
chocolate turkey
04-22-2006, 09:05 AM
One trick I have used successfully was a piece of emery cloth jambed in between a socket (impact) and the wheel lock nut. Hammer the socket over the nut and use either an impact or a bar. Worked more often than not. Also, use valve lapping compound, it has enough grit to make a bind.
If all else fails, there are inexpensive removal tools available on the rack at your local NAPA.
Brian
Brian K. Curtis
stude_s
04-22-2006, 10:02 PM
Follow the emery cloth and socket idea! I have used this several times, when customers bring in there cars /trucks and have lost the lock keys. From working in a major x-brand dealership this is almost the same as the "kits" the tool vendors sell, without the cost.
studebakerkid
04-25-2006, 02:34 AM
I have done it out in the boonies using a splitting maul and a sledge hammer. Took off four of them one afternoon fro some idiot that drove his car where he shouldn't have and then got a flat.
In the shop I have used an air chisel many times.
65 2dr sedan
64 2dr sedan (Pinkie)
61 V8 Tcab
61 Tcab 20R powered
54 Champion Wagon
