View Full Version : 1953 Auto Trans
glen
04-17-2006, 02:41 PM
I thought awhile back that there was a discussion on
the type of transmission fluid to use in the DG's and
that inorder to check the fluid level, the transmission
had to be put in "L" while doing the check. Can't seem
to find that discussion. I am I "Zoning" out here in the
Northern Zone of AZ or what? I just want to make sure
that dexronIII/mercon is ok....and the method to check
is proper.
Thanks
Glen Brose
53 Champion 2 dr Sedan
studegary
04-17-2006, 02:56 PM
Dexron and check with the transmission well warmed up and in Low (after shifting through the gears). Only add a little at a time and recheck. Do not overfill. I recommend (and do it myself) changing the fluid in the transmission and torque converter on an annual basis in those BW DG transmissions.
1959 DeLuxe pickup (restomod)
Eman
04-17-2006, 02:58 PM
At least on my '51, you are correct about putting the car in "L" in order to check and add fluid. Also, I believe DexronIII/Mercon is okay to use as well as Type F, which is what I just filled up with.
1951 Commander Starlight Coupe (aka "Stella")
www.bulletshots.net
www.bulletshots.net/blog
glen
04-17-2006, 02:59 PM
Thanks Gary and Eman, I appreciate the responses with the
how to's
Glen Brose
64V-K7
Believe it or not, when first produced, the manual called for 10W10 engine oil in the transmission. That aside, Dexron-Mercon III is fine. My car has been driven over 15K miles, with Dexron, without a problem. If you're unsure about what's in it, it would be better to drain the entire trans, including the converter and refill with Dexron.
You fill it by warming it up, setting the handbrake and putting the lever in "L" (Better to have a buddy stand in the brake tho) Fill to just below the top mark. Never overfill, as it could cause foaming
glen
04-17-2006, 03:02 PM
Thanks 55Prez....I will remember the buddy
part...
Glen Brose
