View Full Version : brakes
lew
04-14-2006, 02:31 PM
Hi guys,
I need help. I have a 1963 avanti & have replaced all brake cly, master cly, brake booster,
check valve, resurface front rotors, front pad, rear shoes, rear brake drum & brake tubing,
brake tubing fittings, silicone brake fluid& stop light switch.
but i still can not get more than 1 in of brakes.
Thanks Lew
lew
04-14-2006, 04:34 PM
Hey I found out if i disconnett the vac hose on the power steering i have 2 in of brakes???
any ideas.
Lew
04-14-2006, 05:56 PM
quote:Originally posted by lew
Hi guys,
Thanks Lew
Lew,
Not sure what you mean by 1" of brakes. Do you mean the brake pedal goes down 1" from the stop at the top until the pedal can't be depressed any more? If so, I think this is about normal (at least for power brake cars). Do the brakes "feel" normal?
lew
04-14-2006, 06:26 PM
Sorry i was not clear. The pedal with the motor runing goes down to 1 inch or less from the floor.
With the vac hose on the power brakes off the pedal it goes down to 2 from the floor.
Thanks Lew
sbca96
04-14-2006, 06:53 PM
I would assume you have air in the lines, OR the rod on the booster
is not adjusted correctly. There is a specified amount that the shaft
coming out of the booster needs to extend too. If the shaft is too
short, then it could result in a lower pedal.
Tom
1963 Studebaker Avanti (http://hometown.aol.com/sbca96/images/63avanti.jpg), 102,000, custom made brake brackets to mount 1998 Mustang GT 4 wheel disc brakes (soon to get 13" Cobra front brakes, 2003 Mustang Cobra 17" wheels, GM altenator, will be getting : 97 Camaro Z28 tan leather seats, 97 Camaro Z28 T-56 6-speed trans, Ported 'R3' style Avanti heads with stainless full flow valves, 'R3' 276 duration cam w/chrysler solid lifters, shortened push rods, aluminum cam gear, Edelbrock AFB Carb, GM HEI distributor, 8.8mm plug wires, waiting in the garage.
bige
04-14-2006, 07:05 PM
Lew,
Did you check the pushrod length? Not unusual for the pedal to be higher with the booster disconnected. You have a compound problem if the pushrod isn't right because your not getting enough travel to push the air out when you attempt to bleed.
I'm assuming you bled the master cylnder before you hooked up the lines. Also, when the system is emptied it's hard to get all the air out bleeding the old fashioned way of "pump and hold". Power bleeding is the best but I've had good resuts with the "one man bleeders" but I just use the cup and have someone pump the pedal until I can't see any air bubbles. Just have to make sure you always have the hose in the cup submerged in fluid and you don't run the master dry.
Another thing to check is that the calipers aren't switched so that the bleeder screw is not up on top of the caliper. If it's pointing down air can get trapped at the top of the caliper reservoir and not get bled out.
Ernie R2 R5388
R2 R5388
unclemiltie
04-15-2006, 08:58 AM
I had a similar situation once when I changed a MC. The MC or kit must have been different.
Measure the distance from the back of the MC to the end of the piston where the push rod presses against. Measure this on both the old and the new one. If there is a difference, adjust the push rod to make up the difference. This solvrd my problem.
