View Full Version : stock bolt pattern
studelover
03-19-2007, 10:00 PM
What is the stock bolt pattern for a 1961 hawk, is it 5/1/4? how wide can I go will a 17.7 fit?
Studebakers forever!
03-19-2007, 10:12 PM
Bolt pattern (as with all Stude cars from '51 up) is 5 on 5 1/2".
17.7" won't fit unless you tub it. :D
blackhawk61
03-19-2007, 10:17 PM
Dick....I think You meant 5 on 4 1/2" circle ;)
1961 Hawk 4BC,4-SPEED,TT
http://sixty5short.chevytalk-supporter.org/blackhawk61/rrhawk.jpg
Lewisville,NC
(formerly chevpartsman)
JDP
03-19-2007, 10:18 PM
I thought you wanted the wheel bolt pattern ( 5 by 4 1/2)
64 Commander 2 dr.
64 GT Hawk R2 clone
64 Daytona HT
63 Cruiser
63 R2 4 speed GT Hawk (Black)
63 Avanti R1
63 Daytona convert
63 Lark 2 door
63 Lark 2 door #2
62 Daytona HT/ 4 speed
62 Lark 2 door
60 Lark HT
60 Hawk
59 3E truck
52 Starliner
51 Commander
03-19-2007, 10:43 PM
That's what I meant [:I].
(hey, I was only off by an inch [B)])
60Lark
03-19-2007, 11:36 PM
Only works in Horseshoes :D
http://im1.shutterfly.com/procserv/47b6ce20b3127cce8d0e3b50356c00000000400CcNWTlozYsb http://im1.shutterfly.com/procserv/47b6dc03b3127cce970d7aafd15f00000010100CcNWTlozYsb
Studebaker Fever
60 Lark
51 Champion
Phil
Arnold, Missouri
studelover
03-20-2007, 04:40 AM
OK 15 5 1/4 bolt pattern, with the 17.7 is the .7 getting me in trouble? Could it be just 17.5? Our stock wheels are just 15.5 right?
Swifster
03-20-2007, 06:14 AM
The bolt pattern is 5X4-1/2. That .2 doesn't make a lot of difference. The widest wheel that will mount without rubbing will be a 6" wide wheel, and even then it will depend on the tire used. Remember, even the Corvettes of the time were running 15X5 wheels and using 7.75X15 rubber. Not a lot of room in the wheelhouses without doing minitubs.
Tom - Valrico, FL
1964 Studebaker Daytona
http://i74.photobucket.com/albums/i280/Swifster/1965_Studebaker_Commander_front198x.jpg
DEEPNHOCK
03-20-2007, 08:46 AM
Depends...
Stude used a 5X4&1/2 bolt pattern with a 6.70x15 bias ply tire (on 1961 Hawks').
Have your wheel/tire guy check your tire profile compared to the stock setup.
It 'might' fit with a 7" wide wheel, depending on the offset, and the sidewall profile.
But why you'd want to go there is another matter;)
http://i77.photobucket.com/albums/j54/deepnhock/Jeff%20Rice%20Studebaker%20Pictures/1937StudebakerCoupeExpressJeffRicee.jpg
DEEPNHOCK at Gmail.com
Brooklet, Georgia
'61 Hawk (project)
1956 Hawk
03-20-2007, 02:10 PM
You can fit an 8" wide wheel on the back of a Hawk with some careful measuring. I am running an 8" wheel with 255/60 tires. The front is more of a problem, but I wanted skinny tires on the front anyway.
http://thumb2.webshots.net/t/60/160/3/37/65/2174337650089385702RYbvvP_th.jpg
studelover, are you really trying to fit a 17.7" wide wheel on your car? Or a 17" tall wheel?
David
studelover
03-20-2007, 06:57 PM
Deep hock, I need something to make my hawk stand out. These hub cap just don't cut it. I saw some 16 and 17 inch wheels that have tire packages that I think can make the car a hit. The company Forte has a wheel that would look great on a hawk however it needs to be a 16x6 with a 205 45 16 I think It would fit. I would be giving up the white wall though. The color of my car and the interior must all be on the same level wheels and tires included[8)].
