View Full Version : water pump specs
Kdancy
04-12-2006, 10:50 AM
I have a new water pump for the Lark's 289. I just checked the clearance for the impeller to housing flange and am getting .42.
From the top of the impeller to the gasket area of flange is .861.
The Stude service letter says the specs are .934--.938. Looks like I need to press the shaft on thru the impeller so that it will have another .073+ clearance.
I'm assuming this moves the impeller closer to the pump housing for better suction or movement of water thru the system ?
53commander HDTP
53 Champion HDTP
61 Cursed Purple Hawk
64 Champ long bed V8
64 GT
N8N
04-12-2006, 12:05 PM
ISTM I remember someone telling me that some of the rebuilt pumps were coming through with the impeller pressed on too far. In fact I saw a well known vendor "adjusting" the fit of a water pump with a gear puller last swap meet I attended.
62 Daytona hardtop
Alan
04-12-2006, 04:23 PM
There is a seal behind the impeller and if you move it out, you see that hole in the casting? Some green stuff will suddenly appear.
Kdancy
04-13-2006, 07:55 AM
I checked 4 pumps I had on hand, one used one and 3 new ones. All of them were out of spec. I took the old one and pressed the shaft out of the impeller and housing just to see exactly how it was put together. Re-pressed it all back in to proper specs.
53commander HDTP
53 Champion HDTP
64 GT
Kdancy
04-13-2006, 12:27 PM
Well, back to the drawing board. I am looking at both the manual and the Studebaker service letter from July 10, 1962. When I get the impeller to the .934 spec (top of impeller back to pump housing flange surface) the other side of impeller spec (bottom of impeller to flange lip) goes to .125 and the manual says this should not exceed .90 ---- I would think the .934 distance is more important as this also effects the distance of the impeller to the water pump housing thus affecting "water suction" ???
Any insight ?
53commander HDTP
53 Champion HDTP
64 GT
Kdancy
04-15-2006, 12:05 PM
Water pump comparison pictures.
New Link
http://community.webshots.com/album/549512572HHjaYs
curt
04-17-2006, 08:18 AM
What is the expected problem for us folks that have out of spec water pumps?
JDP
04-17-2006, 10:44 AM
I guess they would not pump as well,now I'll worry about it, while before, I would just slap a new one on. :)
64 R2 4 speed Challenger
63 R2 4 speed GT Hawk
63 Avanti
54 3R Pickup
studegary
04-17-2006, 02:51 PM
People experienced cooling problems (overheating) with their cars with the defective/out of spec. V8 water pumps. I assume that this is due to an inadequate flow of coolant.
1959 DeLuxe pickup (restomod)
Kdancy
04-18-2006, 07:27 AM
My friend and SDC member Jerry, started running warm (fla) after installing a new pump, didn't think it could be the pump.
All the one's I checked were around .80 out. That moves the impeller up away from the water pump housing, decreasing suction and flow of water thru the system. There is a reason Studebaker put out the different specs in the 1962 Service letter. Glad I read the info and got a copy of the service letter.
53commander HDTP
53 Champion HDTP
64 GT
curt
04-18-2006, 09:01 AM
Will any of you be at the National this year? I have a new H20 pump and would like it measured as to in or out of specs. It is my spare pump.
wayne
05-18-2006, 08:39 PM
I would like to thank everyone for your input because I put on a rebuilt pump today . After reading the warning the other day I checked the pump & it was out of specs so I put it in specs before I installed it. Has anyone tried to contact the rebuiders? I talked to the auto parts place were I bought it and said if I could get I copy of the manuel page they would contact the rebuild shop
