Can anybody give some advice on what to do about all this hard crud that the good folks of Studebaker (or maybe the dealer) sprayed all over my car, inside and out, 53 years ago? What do you all do with it? Do you clean it up and paint over it? Or remove it all? Would it be appropriate to paint over it (either its original black color or Loma gray trunk color)? I've removed small amounts of it in the trunk around the rear body mounts to repair a nickel sized rust hole. There is no other rust on the car that I can find, so I'm reluctant to remove all this undercoating just for the purpose of searching for hidden rust. Also, the inside of the trunk lid has some compound (acoustic?) that appears to have been sprayed on after the metal was painted but before assembly of the outer shell to the inner stiffeners. There is some light surface rust on the inside of the trunk lid so I would like to paint it. What do you do with this compound? Can it be painted over? I guess if painted over it would not look factory correct, would it? Any feedback on this would be appreciated!
I'm sure that removal of all this undercoating is a major PITA!
Thanks,
Charles Schneider
Raynham MA
'53 Champion Starlight Coupe
'60 Lark VIII
'50 2R5
Thanks,
Charles Schneider
Raynham MA
'60 Lark VIII
'50 2R5
