I'm having an oil pressure problem with the flathead six in my 1957 Silver Hawk. When the engine first starts up, the oil pressure gauge reads a solid 40 lbs driving and 20 lbs at idle. However, the pressure began to drop within the 1st half mile of driving and got down below 20 lbs before I could get home. Under the hood, some oil had been sprayed around on the drivers side, but not a huge amount. I checked the oil and it was down a bit, but still showed about 80% full on the dipstick. This has happened the last two times I have taken the car out.
I tried to check for an oil leak without driving the car. Like before, the oil pressure started off just a bit over 40 lbs with the engine revved, and then began to drop. However, there was no sign of oil leaking under the hood. I continued to rev the engine while looking under the hood and could not spot a drop. It seems to only spray the oil around when driving. Any ideas? Thanks.
