View Full Version : Information for a automatic Transmission 1951 Stud
Studebaker1951
03-20-2006, 10:56 AM
Hi, my Name :Dieter Oskar Paul.
I am from Gremany.
I need information to a 1951 automatick transmission.
I canīt drive back with the car.
My car is a 6 cyl. four door sedan.
I have annother 1951 Studebaker Champion, 6 cyl. two door car.
I restore it later because there is no time in the next month.
Thank you for information.
Dieter
Best regards
D.O.Paul
studegary
03-20-2006, 03:58 PM
If I interpret your question correctly (your English is better than my German), you can not get your '51 with a DG200 automatic transmission to back up/reverse. If this is the case, the most likely things are; 1) fluid level is low (check it per the owner's or shop manual), 2) your shift linkage is out of adjustment, 3) there is a blown out section in the gasket in the control valve assembly (most likely) or 4) you have a band problem.
