View Full Version : Tranmission Fluid & air box
kenda
03-20-2006, 06:57 AM
I have two questions re '57 Golden Hawk.
The tranmission has been overhauled and I'm getting conflicting information re tranmission fluid, ATF-A is no longer available, Advance & NPPA have F or FA. One recommendation was to use Dexron but the label warns against using in Ford tranmissions. What to use?
The second issue involves the Supercharger air nox -- it has 2 threaded 3/8" holes, one on the front and one on the top of the box. This is an older box as it did not have a "flapper" hole in the top. (I've since installed a flapper) but what are the two 3/8" holes for?
curt
03-20-2006, 08:02 AM
My Ford traney uses Dextron. I wrote Quaker State years ago about type A fluid ,they said use Dextron.I'm sure others will respond to your question.
03-20-2006, 10:54 AM
Either trans fluid can be used. Type F will provide slightly firmer shifts.:D
