Can anyone give me the output in PSI and GPM of the power steering pump on a '64 Daytona? [?] Thanks
PS pump output
PSI depends on whose manual you look at. Minimum of 500psi or 750psi at idle with open tester valve. (I'd go with 750). Few shops have those testers, in fact some car makers no longer recommend the closed-valve pressure test because it can wreck a pump so quickly. As far as gpm or flow rate, you might be able to get that information from a rebuilder like Cardone.
Dwain G.Restorations by Skip Towne
