View Full Version : Stude frame question
ddub
03-15-2006, 02:04 PM
I've been reading here about frames and have a simple question. I see references to "top hat" style frame. Help me out with the meaning of this term please.
53 Commander Hardtop
64 Champ 1/2 ton
WA state
new53
03-15-2006, 03:56 PM
I haven't heard the phrase "top hat", but the term "hat channel" refers to structural pieces that look like a slice through a flat brimmed hat. Here's a page that has pictures:
http://wx4.org/to/wagons/usefulstuff/frames/frames.html
This has nothing to do with anything I'm working on, but it does explain things. In a previous post about 53 frames there is a reference to hat channels reinforcing a frame. I believe the idea was to continuously weld hat channel upsidedown (brim side up), hence the reference to cutting holes in the channel to prevent water from getting traped.
In general, for the same steel gauge, tubes are stronger than "hat" or "C" channel. That's why "Boxing" a "hat" or "C" channel frame adds strength.
G. Howes
ddub
03-15-2006, 07:31 PM
Thanks, that clears it up.
64 Champ 1/2 ton
WA state
03-15-2006, 10:32 PM
And Stude "hat channels" are already "boxed".;)
Sonny
03-15-2006, 10:44 PM
You'll probably hear the characterization of the Stude frame as a "top hat" style frame quite a bit ddub. As "new53" has explained, the "look" of the Studebaker frame resembles a flat topped, flat brimmed hat, as you would normally wear it. The depiction of the Jeep frame, (that new53 provided a link for), was of the "C-channel" style, and is the type that was used in Stude trucks, (as well as many other makers). The C-channel type frame has evolved to become the present day, default, "standard" choice for heavier vehicles and trucks.
The Stude car frame also incorporates a thin, flat steel sheet welded to the bottom of the "hat brim". I doubt that the thin sheet gives much added lateral strength, but it does allow the frame to absorb greater tensional loads, (twist). The Stude frame, (in good order), is strong, light and flexible, designed to promote better ride and handling for the street, no doubt.
Studebaker was not alone in using the top hat style frame, in particular, Chevy used it up to about '54, (I think). Anyway, Studebaker did make frames, (various years/models), of varying gauge or thickness. As a rule-of-thumb in trying to figure out which Studebaker frame is which, the 6 cylinder cars usually got the "lighter" frame, while the majority of V8 and export cars got the heavier gauge frame.
There have been a few cracks found around the control arm bolt areas and front cross-member attach point on some model Studes, that subject is well covered in other discussions on the forums.
Sonny
http://RacingStudebakers.com
03-15-2006, 11:38 PM
quote:Originally posted by Sonny
Sonny
Welcome back, Sonny!! :)
Sonny
03-16-2006, 09:05 PM
Sonny
Why thank you very much Sir Richard! ALL-ways good to hear from you as well! Hopefully I can spend some time here, but since I've been gone so long my own website is a mess, and where I'm gonna have to concentrate some serious time. I'm elated that the SDC forums have matured so quickly! Awesome!
In any event, thanks again Dick, you've always been the finest of gentlemen and I truly appreciate your consideration. BTW, Awesome signature picture!
Sonny
