View Full Version : wheel/tire question
new53
03-07-2006, 02:55 PM
I want to put radial WWW on my 53 HT. I'd like a wider tire, but I understand that there are clearance issues. Looking back through TW back issues, they recommend chrysler wheels and P195 tires. They say P205's might work, but cause handling problems. So here's the question - Assuming that the original wheels and tires are saved for show, what is the best wheel/tire combination for modern radials and everyday driving on a stock 53 HT? I've read that wider offsets can cause bearing problems, so what is the best offset? Anybody have a source for the right wheels, or is it easier to just hit the local junk yards?
G. Howes
03-07-2006, 03:09 PM
I've recommended the 195s all along. However, it's come to pass that these are just about extinct from the tire market (yes, I know there's some General's available, but they're blackwall only) so 205s are it.
My tire guy assures me that 70-series 205s have the same outer diameter of 195 75 series - and those (70 series 205s) can easily be had with white walls.
I'm running some Mopar 15" wheels I found on an '80s Dodge in a wrecking yard (sorry I can't be more specific than that but it's been two years since I got them). There's a fella selling new replacement wheels via his ad in Turning Wheels lately.
I'm sure other's here will elaborate more. Did you seach this site's archives? We've discussed this several times before.:D
Eman
03-07-2006, 07:10 PM
FYI - I just got some 205/75/15 Uniroyals (thin WW) put on Stella, and she drives fine with them so far. Of course, the tires that WERE on there were 215/75/15s that hardly held any air, so the difference was dramatic for me.:)
1951 Commander Starlight Coupe (aka "Stella")
www.bulletshots.net
www.bulletshots.net/blog
new53
03-07-2006, 09:25 PM
Thanks for the help - and I gave myself a slap on the forehead for not checking the archives first. Looks like it's been covered well already. I will say that I put cooker radial ww tires ($$!) on my 41 chevy PU and the handling is great - no problems, but it doesn't get alot of hard driving. I used the original 41 artillery rims, and cooker said to just install tubes to be safe. I think the tubes ran $9 each. The local Discount Tire refused to install the tubes (said it was against the law?!), so I went to a Goodyear dealer - and they were much more helpful.
G. Howes
sbca96
03-08-2006, 02:54 PM
http://www.studebakerdriversclub.com/sdc_forum/topic.asp?TOPIC_ID=3191
I am running 17x8 wheels and 245/45 R17 Essenza tires. I ran 245/60's
on 14 inch rims on my 60 Hawk for years, and even lowered, it never
rubbed anything. The rims on the Hawk were 7 inch wide. If you live
in California, I would give you a deal on them, they need a polish.
A friend of mine is running 15 x 7 on his 56 Sky Hawk, to fit over
his Steeltech brakes. The 14's work on a drum brake car, but not a
disc (unless you mod them like I did to the stude ones years ago).
Tom
1963 Studebaker Avanti (http://hometown.aol.com/sbca96/images/63avanti.jpg), 102,000, custom made brake brackets to mount 1998 Mustang GT 4 wheel disc brakes (soon to get 13" Cobra front brakes, 2003 Mustang Cobra 17" wheels, GM altenator, will be getting : 97 Camaro Z28 tan leather seats, 97 Camaro Z28 T-56 6-speed trans, Ported 'R3' style Avanti heads with stainless full flow valves, 'R3' 276 duration cam w/chrysler solid lifters, shortened push rods, aluminum cam gear, Edelbrock AFB Carb, GM HEI distributor, 8.8mm plug wires, waiting in the garage.
