Chevy 194 pistons in a 259?
  • Chevy 194 pistons in a 259?
    I think long time ago I read in a turning wheel that chevy 194
    pistons can be used in a 259.
    If so, what modifications have to be made.
    I am thinking perhaps the piston pin holes have to be reamed to the 259's diameter?
    If anyone knows, please comment.
    Thanks
    Paul
    Yes, I do believe they will work with some mods, the bore & stroke are the same, the 194 has a bore of 3.563, our studes have a bore of 3.5625, which is real close! So they should work, maybe. Unless you have easy access to 194 pistons, I would support our vendors and get stude pistons.
    Good luck!
    1955 President
    Job: Student @ Penn State
    Love of Studebakers?: High
      Gotta remember to check the compression height.
      The distance from the center of the wrist pin to the deck of the piston. I believe they are different.
        Thanks for the ones that answered my query.
        If any one remembers the turning wheel article on this I would appreciate knowing the year and issue.
