View Full Version : oil filter
Mr. Dan0
02-19-2006, 07:21 PM
What and where do I hook up to put a oil filter on the 49champ?
and can I buy what I need local?
02-20-2006, 06:48 PM
I doubt you'll find something local unless it's at some old junkyard. You need the filter, the filter cannister, the bracket to mount it utilizing a couple of the head bolts, the input line W/fittings and the return line W/fittings. And one of the two input line fittings needs to be a restricted fitting that minimizes the volume of oil that can flow thru it. This is so you don't dump all your oil pressure thru the filter and back into the engine[xx(]
The input line taps (usually) the frontmost oil gallery outlet on the right side of the engine and routes around to the left side of the engine, where the oil filter cannister mounts. The return line goes from the cannister to a fitting at the base of the oil filler tube - the one that the dipstick sticks into on your car.:D
Mr. Dan0
02-20-2006, 07:39 PM
ANY PICS. BIGG?
just wondering if 'in you had any I can get a better idea. on location .
Okay so where can I buy what I need?
rockne10
02-20-2006, 09:50 PM
The feed and return lines are available from SI. For the filter cannister and brackets you'll probably need to find a donor, swap meets, put a want-ad in Turning wheels or hope someone here will offer you their spare.
Blue 15G
02-21-2006, 08:22 AM
I've been wanting to install an oil filter on my '54 Champion six. However, I don't think that this engine has ever been apart, at least not for decades, and I'm more than a little reluctant to loosen any head bolts to install the mounting bracket. Or am I worrying needlessly?
02-21-2006, 03:46 PM
I don't think you need to worry 15G.
Dan O, I think I have a setup on a core 6 I have here. Modestly priced and I'll take pics before I remove it. E-mail me if you're interested.:D
CHAMP
02-22-2006, 10:05 AM
MR.BIGGS, I'VE GIVEN MR. DANO A DAY TO RESPOND TO YOUR OIL FILTER OFFER, SO IF HE IS NOT INTERESTED IN OIL FILTER I AM! THANKS CHAMP.:)
02-22-2006, 11:21 AM
Actualy, he did respond - BUT... I may have another setup out in the parts shed. I'll have to look an see today.:D
CHAMP
02-22-2006, 01:48 PM
THANKS MR. BIGGS I'LL CHECK AGAIN LATER. CHAMP:)
