View Full Version : 2bbl Stromberg XX Question
55Commander
02-12-2006, 10:00 PM
I want to collect a couple Stromberg 2bbl's for a 2X2 intake.
I am looking for the ones that face backwards.
What years are they off? (53-55??)
Is there a special designation other than Stromberg XX?
Can anybody tell me the rebuild part # off the top of their head?
Who sells a wrench to get the jets out?
Any other information you think will be helpfu please chime in.
Thanks
whacker
02-12-2006, 11:49 PM
There really isn't a lot of difference between the back draft WW and the regular WW - just the top casting and the choke linkage. If you can find a couple of backdraft parts carbs and a couple of good downdraft WW's, you can mix and match to make two good backdrafts. I'm working on a setup like that myself right now.
Alan
02-13-2006, 12:38 AM
Are you in So. Cal and comming to Peterson this week end the 19th.? If you are I will bring one with me.
DEEPNHOCK
02-13-2006, 08:32 AM
I have two off of two different V-8 Stude's..(as well as a few extra WW 2bbls)
You won't be able to run air filter(s) on them as the inlets will end up within an inch of the other carb.
I have built adapters to move the carbs up and away from one another so air filters can be used.. But if you do that and you have a '53/55 C/K you may have hood clearance issues.
See for some pictures: http://community.webshots.com/album/226658494pQsOSR
Hope the info helps.
Thanks
DEEPNHOCK at Cox.net
Ocala, FL.
'37 Coupe Express
'37 Coupe Express Trailer
'61 Hawk
55Commander
02-13-2006, 10:11 AM
This is exactly what I was looking for. So the Backdraft and newer
carbs share everything but the top.
What year should I use for a rebuild kit??
I won't ba making it to Peterson, I am in Texas. Thanks for the offer though.
Clearance shouldn't be a problem as this motor is in a hood-less Model
A pickup. :D
02-13-2006, 02:07 PM
53 thru 58. but thru those years, they're not all of the same CFM capacity. ;)
I wonder if you couldn't use a backdraft one on the front mount and fabricate a "T" of sorts to use a later type one in the rear position. (same CFM rating, of course):D
I believe the rebuild kits you can get from NAPA or other stores will have whatever gaskets you need to accomodate all variants. Notice I said "I believe" as opposed to "I know for sure"
As to those jets, last time I did one I used a smallish pair of needle-nosed pliers to unscrew them. [^]
55Commander
02-13-2006, 03:47 PM
Multiple CFM ratings, now you've done it MrB. ;)
The one I have has a Venturi size stamped on the side,
I assume they all do.
I guess I need to get my math book out and figure the
CFM required, then play with jets.
I might try and make a jet tool tonight, they are stuck
in the carb I have.
DeepNHok
Nice work on the spacer plates, I'll take your prototypes please. :D
What is the purpose of the plugged hole in the exhaust crossover?
Is that an Edmunds Custom??
Chicken Hawk
02-13-2006, 07:24 PM
I have the tool to remove the jets. If you want to borrow it, send me your mailing address.
Ted
in the carb I have.
DeepNHok
55Commander
02-14-2006, 02:38 PM
That would be great.
If I have one to look at I can make my own.
I promise to send it right back. I will e-mail you my addy.
Thanks.
By the way Ted, I got an R2+ cam from you awhile back and it performs
great, really made my 289 come alive.
TZ
Chicken Hawk
02-14-2006, 09:26 PM
Will send it out tomorrow. Glad the cam worked out for you.
Ted
Thanks.
TZ
55Commander
02-18-2006, 07:01 PM
Thanks Ted,
I got the socket this morning and made my own version from a deep
well 5mm Craftsman socket this afternoon.
I'll get it back in the mail on Tue. after the holiday.
