View Full Version : Overcharging GT
55s
02-09-2006, 09:28 PM
My 63 GT appears to be overcharging (up at end of +35 amps). Four wires connected to back of alternator. One large faded yellow one with small black wire, one medium faded yellow on attached to spade connector on back, and another faded yellow one attached to ground beside ballast resistor.
The black wire currently is not connected to the condensor. It may have broken off. Would this cause an overcharge. If so, what value of condensor should replace it?
THanks for any advice.
Paul
JDP
02-09-2006, 10:19 PM
That's just for radio static suspression, no effect. Replace the regulator with a 69 MOPAR unit. (about $12 from Autozone/pep Boys.
64 GT Hawk
64 R2 4 speed Challenger
63 R2 4 speed GT Hawk
53 Street rod
wagone
02-11-2006, 02:48 PM
At the risk of stating the obvious, are you sure it is over charging or has winter just left you with a partially discharged battery?;)
raprice
02-11-2006, 05:35 PM
You really should check out the charging system. It sounds like your voltage regulator isn't functioning properly. If not attended to, it's possible that you can have your battery explode on you (that's the extreme).
I had such a problem and noticed that my battery was starting to bulge.
The regulator wasn't working rightl. A new regulator fixed it.
Rog
55s
02-13-2006, 05:41 PM
Thank you. It was the regulator. Now my black unit is grey, and shaped a little differently, but all the holes and connections were the same.
Paul
JDP
02-13-2006, 07:45 PM
You can sometimes swap the cover, or at least paint it black if it bothers you.
64 GT Hawk
63 Daytona Convert.
53 Street rod
rrausch
02-13-2006, 11:26 PM
I don't know if they are still doing it, but Sears, as late as 4 years ago, would offer a free electrical diagnostic service at their service centers. The probably still do it. With their test equipment they could tell easily if the problem was battery, gen, volt. reg., or short. In 1990 I restored a '54 Chebby 3/4 ton truck, and every time the electrical system went KooKoo I'd just roll on down to Sears. If it was the battery, I'd buy a Sears battery just to make them happy!
1953 Chev. 210 Convertible, 261 6cyl w/Offy dual intake (But I always did love Studebakers!)
1995 Dodge/Cummins Pickup, 250 HP, 620 Ft. Lbs. of Torque, ATS trans.
