View Full Version : Flex plate nuts?
showbizkid
03-15-2007, 06:04 PM
When I took my engine apart, the old flex plate was held on with castellated nuts:
http://i132.photobucket.com/albums/q26/clarknovak/Engine%20pull/DSCN0566.jpg
Reading the parts manual, what's specified is "Lock Nut - 3/8" x 24." Can I just use plain 3/8" nuts with lock washers, or do I need to hunt down something esoteric?
Clark in San Diego
'63 F2/Lark Standard
03-15-2007, 07:16 PM
They LOOK castellated, but they're actually self-locking nuts. The "castled" part is crimped ever-so-slightly to effect a grip on the threads. I'd find something similar. They make self-locking nuts without those cuts or fibre or plastic inserts. Shouldn't be TOO hard to find.:D
Miscreant adrift in
the BerStuda Triangle
sbca96
03-15-2007, 07:51 PM
You most likely want a grade 8 self locking all steel nut. I wouldnt
use a nylock due to the heat it will be exposed too. Napa carries a
wide selection of nuts and bolts at most their stores. The one you
are looking for will look like a regular nut, but be rounded & crushed
on one side. If you look at the threads on the crushed side you will
see that the threads are closed in a little. I used this type on my
700 R4 conversion in the hawk some years ago, and when I removed the
GM flexplate off the Stude crank - they were snug as a bug in a rug.
Tom
hank63
03-16-2007, 07:07 AM
They are actually called "deformed locknuts" and are oval to max 40% of the nut height (if my memory serves me correctly). It is sometimes possible to see the imprints from the jaws used to squash.
I seem to recall they should not be re-used, just as for the nyloc variety.
/H
showbizkid
03-16-2007, 01:11 PM
Here's what I got from NAPA. Doesn't look like the originals, but they swear it will work. Will this do the trick?
http://i132.photobucket.com/albums/q26/clarknovak/Engine%20comes%20home/DSCN0632.jpg
Clark in San Diego
03-16-2007, 01:43 PM
That'll do it!;)
Miscreant adrift in
sbca96
03-16-2007, 08:32 PM
showbizkid, thats the one I was trying to describe - did I come close?[:I]
Tom
showbizkid
03-16-2007, 11:31 PM
Yeah, Tom! Looks just like what you described. Funny - when I went into NAPA, I told the counterkid that I wanted "3/8-inch-24 deformed steel lock nuts." He went and found 'em, and then he asked me "why are they called deformed steel lock nuts?" So I told him it was because the nut was actually deformed by pressure to form the lock.
He looked at me and said "Oh. We just call 'em lock nuts." [:o)]
Clark in San Diego
