I have been pondering what to do to repair the rust-through that has occurred on both rear fenders of my '48 Champion 4-door sedan. It occurs where the sheet metal is doubled up just behind the back doors. The metal is folded over on itself in order to form a flange from top to bottom. The flange is used to bolt the front end of the fender to the car body. Where the metal is doubled up, water (and dirt) is trapped, and this resulted in rust-through, through the outside and inside skin of sheet metal. I have not been able to figure out how to repair this. Should I try to cut out all the rusty metal, and replace both outside and inside skins, or should I leave part of this as one layer of metal only, in order to prevent the same thing from happening again? I wonder if I should just try to weld the flange to the outside skin, and eliminate the inside layer of metal entirely?
doctormap
'48 Champion 4-door
doctormap
'48 Champion 4-door
