View Full Version : Ground Cable
swan hawk
01-23-2006, 09:26 PM
62 GT Hawk - Grounding strap is connected where on the right front fender? Parts book says 22 inch strap - no location - open hole adjacent on the fire wall on the right side facing up - prior non-stock strap bolted to battery shelf support bracket, then the middle bolt of the intake manfold. Battery has positive to front - negative to firewall - not sure that is correct.
Thanks[8]
JDP
01-23-2006, 09:54 PM
The ground strap is only a few inches long. it goes from a bolt on the right motor to the frame mount. The negetive battery cable hooks to the top, outer water pump stud.
64 GT Hawk
64 R2 4 speed Challenger
63 R2 4 speed GT Hawk
53 Street rod
JDP
01-23-2006, 10:04 PM
Here's a pix
http://stude.com/ebay/cable.jpg
64 GT Hawk
53 Street rod
stude freak
01-23-2006, 10:21 PM
Now thats one nice engine compartment n motor.
studegary
01-24-2006, 02:46 PM
Thanks[8]
The ground strap from the battery should go to the engine (water pump stud/bolt), not the body sheet metal. Your battery is either the incorrect model or is in incorrectly. The negative , ground terminal should be towards the front of the car and towards the center of the car. If you can't achieve this configuration, you probably have a 24F (Ford style) rather than a 24 or 24C battery (that you should have).
Avalanche325
01-24-2006, 03:34 PM
All I could see is a big orange air stuffer![:0] Nice.
