View Full Version : Glove box light switch
studeboy28
01-08-2006, 09:53 PM
I need to replace the light switch on the door of the glove box on my 1940 commander. I believe the original was something like a mercury switch in a canister. When you open the door the switch mounted on the back of the clock makes contact in the horizontal position, when the door is closed the switch is vertical and off. Where could I find a switch that works the same way to replace it with? I think I could hide a new one in the old can??
28 dictator
40 commander
Skip Lackie
01-09-2006, 08:31 AM
Most trunk lights and underhood lights have a built-in mercury switch that works the same way, but I have never taken one apart to see what they look like or how they're attached to the lamp assembly. The junk yards have to full of them -- find one that looks like it will fit inside your existing can.
Skip Lackie
studeboy28
01-12-2006, 08:51 PM
In case some one else runs into the same situation. i found a new mercury switch with same size and specs as mine in the Mc master carr catalog. $13 and will all be like original.
28 dictator
40 commander
