View Full Version : 52 Champ - Ross Steering Box needs rebuild???
montereystude
12-26-2005, 07:49 PM
I have a 52 Champion with a Ross Steering gear box. There is a lot of play in the box [:0] and I want to know if there is anywhere to get the steering box rebuilt. (All of the other steering components have been replaced)
I saw an earlier posting that mentioned removing two pins and turning them 90 degrees as a fix for the worn gear box, however when looking at the Stude shop manual and parts book I am unable to identify the pins.
Thanks:D
Alan
12-26-2005, 08:35 PM
http://.ncsdc.com/TechnicalPages/55steering/55steeringrebuild.htm
Is there some thing wrong with ncsdc?
DilloCrafter
12-26-2005, 09:10 PM
Probably only that their website hosting company isn't paying attention. They're likely on a shared server that's hung up and needs a restart.
1955 1/2 Ton Pickup
http://rocketdillo.com/studebaker/misc/images/current_AvaCar.gif
garyash
12-26-2005, 09:25 PM
Here's the pic of the Ross steering box from the M/2R truck manuals, probably the same. You may need to grind off the welds on the pins on the back sides, turn them 90, then re-weld.
http://www.studegarage.com/images/ross_steering.jpg
Gary Ash
Dartmouth, MA
'48 M5
'65 Wagonaire Commander
'63 Wagonaire Standard
www.studegarage.com
montereystude
12-26-2005, 09:30 PM
This link works...
http://ncsdc.com/TechnicalPages/55steering/55steeringrebuild.htm
montereystude
12-26-2005, 09:41 PM
Is it possible to access the pins/make the repair without having to remove the steering box from the car?
It looks to me like it might be possible with a little "modification" (cutting) to the inner fender. Then once the pitman arm is removed the side cover can be removed which will allow removal of the cam lever shaft and access to the pins.
Anyone ever try it this way?
Gary Ash
Dartmouth, MA
'48 M5
www.studegarage.com
Commander51
12-27-2005, 05:46 AM
I don't know how far gone your steering box is, but before you get physical with it, you might want to try some Red Line CV-2 grease in the box first. My '51 steering reservoir leaked, the steering was getting a bit loose and hanging up slightly on return-to-center. I filled the reservoir with CV-2 and it's been fine since. This grease stays in a semi-fluid state won't leak as readily as gear lube, yet flows around the gearing when warm.
montereystude
12-27-2005, 08:18 PM
Anyone tried opening up the steering box while it's still in the car?
