I'm doing rear bearing and brake service on my '51 Champion and have two issues for which I could use some knowledgeable opinions. Both bearings have been removed, cleaned, repacked and re-installed (including the inner seal) on both sides.
1) The bearing race on the left (driver's) side did not go flush into the axle housing while the right side did. Could this be ok? I did notice that there was some what appeared to be baked-on grease residue on the inner face of the axle housing against which the race would be inserted. I cleaned it without removing it completely so I was wondering if this may be causing the problem. The race sticks out about 1/8 inch.
2) I'm not 100% sure about how the shims placed originally. I seem to recall that there some that were on the outside of the outer seal housing, perhaps left there just in case they were needed. Since a dial indicator will be needed to measure the horizontal movement distance of the shaft I tried to move them by hand just to see how loose they might be. Well, they don't appear to move. What's up with that? Are the freshly packed bearings making it all too tight? If so and I can't get a dial indicator to show movement, what should I do?
Thanks,
Chuck Savage
'51 Champion Regal 4dr.
Thanks,
Chuck Savage
