Was it possible to get a V8 in a 1955 Champion? I ask because I have a 1955 champion with a V8 3 speed overdrive. If it was converted, whoever did it did an excellent job. Everything looks like it was there from the factory. The gas line comes up at the fuel pump, throttle linkage is right, all wiring is still in proper location, fan shroud and radiator are right. I haven`t had a chance to check the engine number yet.[?]
1955 Champion V8
Maybe it is a Commander with Champion trim (to fool people or replacement panels). What is the information on the body tag (engine side of cowl, car's right side)? Does the body tag look like it has been changed (Does the paint on the tag match the cowl?)? What is the serial number on the door jamb (Does it look like it has been changed?)? NO, you could not get a V8 in a '55 Champion. Studebaker made some cars to order, but that wouldn't make sense.Gary L.
If the serial# plate on the door jamb starts with a "G", it was a 6 cylinder car to start with for sure. If the body tag on the firewall (near the righthand hood hinge) starts out "16G6- it was/is a Champion at heart.
1963 Daytona project FSNo deceptive flags to prove I'm patriotic - no biblical BS to impress - just ME and Studebakers - as it should be.
The engine serial number should tell you for sure. You should be able to trace it down to either a specific year car or truck, or tell if it is a factory replacement block. Either way, if this is the 4 door on eBay now, it is a nice looking car and the engine swap should only increase the value.
I have a 53 Commander parts car with 55 trim. Apparently, dealers would install newer trim to update the appearance of the car, so it would look like a new car.
In any case, many Champions came from the factory with Regal Trim (the stainless steel side butterknife trim). I am certain this is because it makes the car look faster.
Paul
PaulGary L.
Rationale or not, alot of 55 Champions DID come with the Regal trim option. It may not have been popular with Bourke, but the evidence of how many Regal-trimmed cars are around indicates someone liked it.
Serial number starts with G and the cowl tag starts 16G6 so it must have been a 6 to start with. Whoever did it had to have another car and swap everything over in good detail. Yes it is the car on ebay now. I bought the car like it is. Its a nice daily driver, but not a show car.
Comment? Yup - bogus information! Since, body and interior-wise, you'd get essentially the SAME car, if you opted for a Commander over a Champion, What would be the sense of Studebaker defeating their own marketing strategy??? Doesn't make sense!
The two different lines were virtually the same save for their drivelines and the brakes and springs they were fitted with. Since the brakes even on the Commander line were marginal, at best, in their effectiveness - imagine trusting the added power and weight of the V8 to the wimpy brakes of the Champion! Then there's the issue of the lighter duty rear axle behind the V8. It would have a very short working life.
So total up the changes required to make the car capable of handling the V8 - Different wiring, heavier duty springs, bigger brakes, beefier transmission and drive shaft and rear axle as well, and guess what??? You've got a Commander with Champion namepltes on it. What have you saved? Nothing.[xx(] There MIGHT be a very minor savings in that the Champion had a lighter gage frame - but then again, would you think Stude would build a car to lesser specs than what they'd designed???[B)]
Copy my argument here and E-mail it back to your "informant". I'd like to here his counterpoint on this.
quote:Originally posted by dr9487
Mr. Biggs, according to Chilton`s Auto Repair Manual, the 1955 Champion and Commander had the same brakes and the same chassis length and tire size. That would indicate the same car just a different engine, wouldn`t it?
As Biggs states..." The two different lines were virtually the same save for their drivelines and the brakes and springs they were fitted with".
If you replaced the Champion brakes, springs, engine, transmission, rear end, drive shaft and frame with those from a Commander, you would have a "virtual" Commander.
-Dick-
(BTW, the last time I can recall that Biggs was wrong was when he thought he was wrong, but turned out he was right. He was wrong to think he was wrong <g>Dick Steinkamp
Bellingham, WA
According to Chilton`s 1955 was the only year that Champion and Commander had the same brakes. Advance Auto Parts and Autozone both show the same brakes system for the both cars in 1955. There`s less than 300 lbs difference in the 2 cars and the v8 engine probably is most of that at 2790 lbs and 3065 lbs.
