What is the difference between an Avanti 289 and a Hawk 289? Are some engine parts interchangable?
Avanti 289 vs. Hawk 289
Some interchanges will work, but not directly or are incorrect. Different pistons, heads, carb, manifold, cam, oil pan, distributor, timing gear, intake & water pump manifolds and more.
64 GT Hawk
64 R2 4 speed Challenger
63 R2 4 speed GT Hawk
53 Street rod
JDP Maryland
What about a crank shaft pulley?
64 GT Hawk
53 Street rod
Not even close. The Avanti, and the Avanti engined Larks/Hawks use a different vibration damper and the Avanti car uses a big, heavy 3 groove cast iron pulley.
64 GT Hawk
53 Street rod
JDP Maryland
I have been looking for a three grove pulley to put on my 289. Going to hook up air, and power steering. That type of pulley will not work?quote:Originally posted by JDP
64 GT Hawk
53 Street rod
No, even if you could mount it on a standard 289, it would not line up with anything. Studebaker just stacks the single pullys with a spacer.
64 GT Hawk
53 Street rod
JDP Maryland
