View Full Version : 3spd w/OD
casey
11-29-2005, 05:53 PM
Can a T86 3 spd w/OD, originally from a V8 car, be used with the Champ 6 cyl? thanks
rockne10
11-29-2005, 09:25 PM
I do believe you'll need the T96.
gordr
11-29-2005, 10:18 PM
If it is a Champ TRUCK six, with a truck bellhousing, then you can use the T86, because that was the tranny used in six cylinder light trucks. You might have to change out or machine down the input shft of the T86; on older models pretty certain you wouod, not sure on Champs.
If you got hold of a truck bellhousing, you could install the T86 behind a Champion six in a car.
I think NOS T96 OD trannies are still available from SASCO.
casey
11-30-2005, 05:46 PM
Excellent info Gord. The bellhousing solution is just what I needed.
gecoe
11-30-2005, 11:15 PM
I believe using the truck bell housing in the car will require relocating the starter to the passanger side of the engine. Not a big deal but one to be aware of.
Gerry
blackhawk
12-10-2005, 03:08 AM
Gerry
This is my recollection too. My '61 Champ Pickup originally had a 6-cyl. engine with a T86OD transmission (truck gears of course). The starter was on the other side like Gerry says. FYI - The weasels I have used also had a T86 transmission instead of the T96.
Dale
