View Full Version : HELP, OWNERs 55 Stude V8 w/automatic tranny DG250M
jgw2
11-26-2005, 02:15 PM
I need immediate help from owner's of 55 Studebaker V8 w/automatic (3-band, Borg Warner DG-250-M) trannies.
1. On the driver's side just rearward of the bellhousing there is an assy called ~ LOW/REV INTERMEDIATE SERVO ASSY and it has a part number that is vertically-oriented reading it UP, and should read something like "25- _ _ _", I believe. Please post what yours reads.
{e.g., for a DG-200, mine reads, "20-517"}
2. Also, on the rear of the tranny there is a TAILSHAFT ASSY w/gov, and the part number reads horizontally.
On a DG-200, e.g., mine reads "20-705"
Please post what yours is and verify that yours has a "25- _ _ _", or whatever yours reads.
THANKS-a-million
John => jgw2@bellsouth.net
curt
11-27-2005, 07:15 PM
Thanks for the note, maybe someone with the proper traney will answer. Good luck with the project, a little information will get you started.
11-27-2005, 08:31 PM
I've just looked at 2 different DG-250Ms I have here. Both have a casting# that reads 20-517DP on that servo housing.
I couldn't find the number on the rear section but to tell the truth, I didn't look too hard. It was cold (by California standards)[8D], dark, and one of the trannies didn't like being disturbed after all this time and it drew blood from my right pinkie.:(
curt
11-28-2005, 08:01 AM
We call them vampire trannies.
jgw2
11-28-2005, 08:38 AM
Thanks, Bob, and sorry about your hurting yourself. The location of the tailshaft extension ID is found and viewed looking forward towards the bellhousing; now, below and to the left of the output shaft or the hole where the yoke slides in.
I am very surprised that the first 2 numbers aren't "25" (DG-250M); mercy me.
Thanks again for your efforts!
John:(
jgw2
11-30-2005, 12:20 PM
Bob, I hope you'll have time to attain the part # for the tailshaft housings (assumed to be the same); thanks again for your efforts!
John[8D]
11-30-2005, 02:58 PM
OK - OK... I went back out to look. The numbers on the DG-250's rear end are 20-705. But then, so's the number on the rear of a DG-150 that I have here. And it's servo housing also says 20-517DP. Maybe this is because it's a 54 or 55 DG-150. I don't know what vintage it is. It was just a "core" tranny that was given to me.:)
jgw2
11-30-2005, 08:13 PM
TAIL HOUSING CASTING # (DG-250 e-mail source): 20-7051
(I wonder if the "1" implies first gear start?)
BORG WARNER #: J.20-7049
JAGUAR #: 7371
STUDEBAKER #: 529776
SERVO HOUSING CASTING #: 20-517DP (Double Piston, apparently)
BORG WARNER #: J.20-517/D
JAGUAR #: 6828
STUDEBAKER #: 535234 (DG-150, DG-150M, DG-200M & DG-250M)
and #: 529710 (DG-200)
Parts just rec'd, supposedly from DG-250M & no DG-250M case:
1. tail housing, # 20-705
2. SERVO, casting # 20-525DP (517 v. 525?) (double piston)
3. VALVE BODY has these 2 #'s: 20-5422 & 20-5613 (mystudebaker.com has the # 537796)
CONCLUSION:
The DG-250 parts rec'd will not physically fit my DG-200 case. I initially ordered a DG-250M donor tranny for good hard parts to replace my damaged parts AND so I could have 1st-gear start. I was send an excellent DG-200 tranny, supposedly 1st-gear start, but was told later it would cause my tranny to fail. Therefore, I can't waste any more time with this project, and I'll put my original valve body back in the tranny and it will stay 2nd-gear start. All the unuseable parts go back at his expense, plus he owes me $120, the way I see it.
What a disaster!
[V]
studegary
11-30-2005, 09:31 PM
Your DG-200 will start in first if you start in LOW or with the throttle floored. Then just shift to Drive (if starting in Low) at the appropriate time. I have done this, but it is best to just replace the DG-200 with a DG-250. I've done several ('55 transmission in '53 car) and it used to be common.
12-01-2005, 12:09 PM
Donor (replacement) DGs are getting tough to find nowdays, Gary.;)
studegary
12-01-2005, 04:09 PM
Tougher than they used to be, Bob/MrBiggs, but probably not as tough here in the rust belt as where you live.
jgw2
12-10-2005, 08:49 PM
We struck a deal (refund of $120 since I didn't get the first gear start or DG-250 initially) and all the unused DG-200 parts, plus the unused DG-250 parts will be returned at his cost.
On Friday the transmission place repairing my original DG-200 called and have the original DG-200 tranny reinstalled and working properly, however, they have ruffled my feathers with excessive, fraudulent and deceptive over charges, and what I consider mistreatment of this customer. Bill of over $2600, including a charge to clean my "tranny cooler" of $59 + tax. hehe What cooler; this one is air cooled?! These business folks are really something, at least the ones I've been running into lately. Mike Dotson, ATR, Anaconda, MT, quoted me $900 to rebuild it. Initially these folks told me "nte $1500".
Monday, I'll go in there with hidden tape recorder and proceed to do battle. I hope to change their mind.
[u]</u>
64V-K7
12-11-2005, 03:08 PM
I have notes from chat groups and email I receive. I believe the first gear start DG's have the "M" appended. My Dg250M starts in 1st and from a light, I can beat the pants off a lot of new rice burners for the first 100 yards or so
RJ
55Pres
64Hawk
70 Avanti
12-11-2005, 03:44 PM
Welcome aboard, Bob! Don't be a stranger here. We could benefit from your expertise. How about posting your fine website's link for these guys to benefit from???:D
64V-K7
12-11-2005, 07:45 PM
Hi Bob,
Happy Holidays....
You're right, I don't frequent this site enough, but I will be looking in a bit more. I thought that retirement would give me all the time to do a lot of things...... Not!
One of the biggest chores, is getting my ride ready for our Lincoln Highway Tour, in 2007. This project has turned into a rendition of "The Flight of the Phoenix", replacing the C-119 with a 64 GT Hawk. The only reason it cast a shadow was fresh paint over the oxidation....
Speaking of shadows, my website is merely, one of it's former self. I don't have all the space that's needed to hold it, so the routine is to constantly move stuff on and off and around. I'm working on a new 'seat of operations'. Maybe, early, next year. In the meantime it's
http://patriot.net/~jonroq/
Best Wishes..
jgw2
01-09-2006, 10:09 AM
Well, I only talked them into about a 10% reduction in costs.
Yesterday a friend of mine rolled her out of the stall, fired her up and decided to drive her around for a while. Paul had previously hinted that since it had been running a little rough that it might need some new, premium gas, plus it was about to run out anyway, so we put 5 gallons in it and almost immediately we realized some benefits. I decided to let him drive it in back and forth in this secluded area. I taught him how to shift it from LO to DR as my linkage is a little loose. 2nd time he took off I noticed the right rear tire leave some rubber. On the 3rd trip I told him to LEAVE SOME RUBBER and he did!! Next trip I said to start off in LO and once the tire begins to spin shift to DR. He did and it burned rubber over 100 feet ( I have to admit that it does have a set of Honda tires on it while the chrome spoked wheels are in the shop for trueing). Anyway, it was fun to see the old Hudson smoking up the area from tire smoke. Even though the tranny still has its leakage problems it seems to be very strong for a DG-200. I just wish I had been able to attain a DG-250 while all this was going on. Overall, I'm happy with it, at least for now.
