View Full Version : Smoking Hawk
valleyguy
11-14-2005, 09:12 AM
My 289v8 Hawk developed a bad case of smoking exhaust.
It seems to have started after I converted the stock 4 bbl carb
to a performer series 1403 (500cfm) 4 bbl carb; I have
done everything the Edelbrock tech guys said to do;;
i.e. installed a fuel pressure regulator, adjusted the
floats, leaned out the carb. No change. Now I'm starting to think that maybe it's an unrelated problem. the smoke is white-gray, and it gets progessively worse as the engine warms up. The plugs
are black(carbon coated) after running the motor.
Bad valve guides? rings? Or does the carb need further
work? Does anyone have an idea of what is going on?
thanks,
11-14-2005, 01:00 PM
White-gray smoke sure ain't from a mal-jetted carb. Could be oil or antifreese by that color description. Does the smoke disperse by drifting well away or does some of it seem to evaporate soon after exiting the tailpipe? A coolant leak will have "smoke" that evaporates to some degree as it's partly steam. An oil leak will produce smoke that doesn't really evaporate but just drifts away to disperse.
Changing the carb alone should not cause either of these possibilities. Are you sure this started right after changine to the Edelbrock?[B)]
Does the car have dual exhausts? If so, is only one side smoking?
valleyguy
11-14-2005, 03:46 PM
the car has dual exhaust and both pipes smoke; upon
starting the car cold, the smoke is light but does not appear to be
evaporating... although I do get a lot of moisture from the
pipes... as the motor warms up the smoke increases, and
I open the throttle it really blows! the plugs do not show
oil but they are black... ??? the car smoked very little before
changing the carb... so I assumed a connection, especially since
it was really loading up when I changed the carb.. motor surging rough running, smnoking etc. After changing to a smaller
carb (500 cfm, the smallest one I could find), and installing
the fuel regulator, it runs much better but still smokes. maybe just
a coincidence? I should also mention that the car is not
driven since I am in the process of restoring the body.
I just start it weekly and let it run for awhile.
any ideas? Thanks much
DEEPNHOCK
11-14-2005, 05:17 PM
Hmmm...The 500cfm should be a great carb for your setup.
But how well does the car run with the new carb?
You say you leaned the carb out.
How? Changed the jets and metering rods?
What number jet and rod came with your carb, and what number rod and jet did you switch to?
How does the exhaust smell?
Does the exhast smell gag you, or is it sweet smelling?
Does the smoke burn your eyeballs?
What year is your car?
Do you have a PCV valve?
Hang in there... You'll get it sorted out:)
DEEPNHOCK at Cox.net
'37 Coupe Express
'37 Coupe Express Trailer
'61 Hawk
valleyguy
11-15-2005, 10:01 AM
Ok, here is what I have done to the carb; per the factory
manual I set the float height (7/16") then the float drop (15/16" - 1"); nothing else. the factory specs are as follows:
main jet primary-.086", main jet secondary- .095" metering rod (primary only) .065x052", step-up spring (5") needle and seat-
.0935". The fuel pressure regulator is set at 5.5 psi.
The motor runs ok, expect when the plugs foul and then it misses;
I have cleaned the plus so many times I could probably do it
blindlfolded.... the smoke smells more acrid than sweet. again,
the smoke gets pregressively worse as the motor warms. There is no PCV valve that I can find. The oil in the crankcase seems fine (although a little low, presumably from burning??), There does not
appear to by any leaks from the radiator or motor. ?? I'm stumped.
If it's not the carb dumping excess fuel into the combustion chamber
than obviously I have a rebuild of some
type to consider.... Thanks for any help you can provide.
11-15-2005, 10:58 AM
That fuel pressures too high for my liking. 4 ought to be max or you DO run the risk of forcing gas past the needle/seat of the carb.
Still - whiteish smoke's not from too much gas. Too rich, and you get black smoke.
Does this thing have power brakes? I've had leaking boosters (leaking internally) that feed brake fluid up thru the vacuum hose, to the manifold.
Are the plugs uniformly black or is it just certain ones?
Does the coolant look clean or murky?[?][?][?]
valleyguy
11-15-2005, 03:13 PM
My car (1958 hawk, 289) has no power brakes nor power steering.
auto tranny.
The plugs are all uniformly black and the the coolant appears clear.
the only thing I have done to the motor since I got the car is a tuneup (plugs, etc.), new aftermarket oil filler tube cap,
the new carb and edelbrock air filter. After looking at the
exhaust smoke again, it is not really white, more gray/black.
I tried different settings on the fuel pressure regulator, including
4 psi you suggested, with no change. This regulator is a cheap job from "Mr. gasket". I would spring for a more expensive regulator if
I was reasonably sure that is the problem. Of course if I was any kind of mechanic, I would have had this solved by now....
Thanks for your help.
hank63
11-16-2005, 02:27 AM
As you haven't driven a lot, the cooling system MIGHT have a leak.If it's a small leak, you'd need to drive a bit before you could see a changed coolant level.
If you know a good reliable radiator shop, ask 'em to pressure check your cooling system twice, once with cold engine and once with warm engine. Shouldn't be a very expensive check, but could show a problem.
/H
curt
11-16-2005, 08:04 AM
Are you adding fluids? Adding oil, adding transmission fluid, adding water? Can the car suck traney fluid up? I know some GM cars can.
DEEPNHOCK
11-16-2005, 08:25 AM
Sounds fat (rich) from your spark plug description.
The factory spec's for an aftermarket carb are quite 'middle of the road' for most 'current' replacement applications. You may need to lean out the carb a bit, until you get the spark plugs to read properly. Get a 'strip kit' that has all the jets and rods in it (or borrow a friends)... Read the chart very carefully to keep the relationship between the jets and rods within the rance. Make small steps with the jets and rods. It is real easy to go too far. Get a note pad and write down where you were (number wise) and record each change. Keep leaning it out intil it reads right on the spark plugs. When it does, it will probably run right too.
Hang in there... You'll get it.
'37 Coupe Express
'61 Hawk
valleyguy
11-16-2005, 08:52 AM
Thanks for all the good input. I'll double check all the fluids,
for leaks and fiddle with the carb some more.
valleyguy
11-20-2005, 10:15 AM
ok, well I rejetted the carb carefully. leaned out the carb,
and and there is no
change with the exhaust smoking. I haven't rechecked the
plugs yet for their condition; the exhuast smoke is still
light colored and there is lots of moisture coming from the
exahust pipes (both), even after the engine is warm; almost like a blown head gasket. But maybe that is from lack of driving the car? None of the fluids are low and the oil in the crankcase
looks good. There is some valve train noise.
Does anyone have an idea where I should start in terms of
checking the motor? I hate to have to
to pull the engine and spring for a rebuild if there is
something I can check/do myself. Or maybe someone knows where I can get a good motor? thanks,
studegary
11-20-2005, 01:41 PM
I would next do a pressure test, holding for about an hour, on the cooling system.
valleyguy
01-11-2006, 02:54 PM
ok, well I have let the car sit for a couple of months pondering
what to do about the motor. I started it up again yesterday and
lo and behold, the exhaust still smokes(go figure); I noticed that the fluid in the radiator now has a silver coating (of something) floating on top, and the same residue is on the radiator cap; it looks/feels like some type of metallic paint but grittier. the fluid level does not seem to have dropped; anyone have an idea of what the cooling system is picking up and from where? thanks,
gordr
01-11-2006, 03:43 PM
That silvery gunk in the cooling system sounds like a stop-leak product such as Aluma-seal. I have used such products and they do leave a residue such as you describe.
Try pulling the spark plugs and checking their appearance. If an engine has a coolant leak affecting one cylinder, quite often the insulator of the plug will be unusually clean and white, rather than the normal light brown.
Some valve train noise is normal with solid lifters.
Have you run through a full tank of fuel? Could be you have some old or contaminated fuel in there.
buddymander
01-14-2006, 11:35 AM
Like Curt said. So, if your tranny does have a modulator, disconnect the vacuum line going to it, and plug it temporarily. Cuz it does sound like you're burning tranny fluid. You'd hafta run it for a while to burn it all outta there.
