Good progress on the brake rebuild here on the '50 Champ Biz Coupe.
It's satisfying to put parts ON the car, rather than taking filthy, busted junk off. So -- I've taken apart the brake pedal, clutch pedal shafts and linkages and got 'em all back together again, cleaned, painted, re-greased, ready to bolt the master cylinder on again. But I can't figure out how to attach the new, very stiff clutch pedal return spring, which goes from a stud on the pedal to a small hole in the outside of the frame. This spring was busted and hanging loose when I started, so I've got no clue. I can't get enough leverage to stretch the bugger. The manual says something about removing the "splash shield". Is that necessary? What is it anyway, a little piece of sheet metal or what? Is there a good tool for this so I don't launch the %^$ spring across the garage again?
