Hi all,
I have a some of questions about the autobody work that I'm doing on my 64 Daytona.
1) We are doing a complete restoration on her. Should we remove all of the old paint? What is the best method to do this with. Chemical?
2) Once the old paint is removed down to bare metal what is the best way to prime it. Do we need to use etching primer and then primer/surfacer? Wet sand the primer/surfacer using glazzing puddy to fill in any small impurfactions then put on the paint?
3) There are a few odd spots where there is just some minor surface rust. What is the best way to get rid of that? Sand blast it or grind it away? Once it is down to bare medal should the medal be treated to kill any rust that is hidden to the eye? If it is to be treated what should be used?
4) Prior to welding in a new patch with a mig welder should the small area around where the welds will be made be sprayed with weld through primer?
3) Once the old paint is removed down to bare metal what is the best way to prime it. Do we need to use etching primer and then primer/surfacer?
Thanks
Steve
Thanks
Steve
