View Full Version : T-cab seat
Kdancy
10-17-2005, 05:38 PM
Is the front seat used in the 59 lark the same as T-cab trucks? My truck is missing it's seat and I have one from a 59 lark sedan. I know the truck had the little wood spacer blocks, is there a difference in mounting brackets between car and truck?
53commander HDTP
53 Champion HDTP
61 Cursed Purple Hawk
64 Champ long bed V8
64 GT
Alan
10-17-2005, 07:07 PM
Have to know the year and body number of your truck before I could tell you the part nos. for the brackets, the only time I have ever seen wood under the seat brackets was a cobbeled up home instalation.
10-17-2005, 10:41 PM
It SEEMS to me that I had to address this question a few years ago, when we were building a Champ outta bits and pieces. We needed a seat and the Lark seat wouldn't straddle the hump in the Champ's floor so we sought and found a sho''nuf Champ seat.:)
Kdancy
10-18-2005, 06:29 AM
It's a 64 long bed v-8 with overdrive. I still have the two blocks of wood that the prier owner pulled out with the orginal seat? I was told this is the way they came. Of course I would like an orginal seat if I can find one or if I have to I can check the junk yard for buckets but I like the bench style seat.
53commander HDTP
53 Champion HDTP
64 GT
Alan
10-18-2005, 12:03 PM
8E5 before or after serial no. 136,332?
Transtar60
10-18-2005, 04:47 PM
Just about any Lark seat will fit as long as you use the little wooden spacers. My 64 Champs original seat was long gone so I used a split back bench seat from a 63 2dr sedan. Later I looked in the Champ parts book and the same seat was optional in Champs. The reason you need the spacers is the floor pan in Champs is bumped up to clear the gas tank.
Transtar60
10-18-2005, 04:53 PM
The wooden spacers have been in all original Champ seat installations I have seen. All or most of those are 7E or 8E
Alan
10-18-2005, 10:23 PM
1344078 for the right and 1344079 for the left if you you use these you won't need the wood blocks.
Kdancy
10-19-2005, 07:39 AM
Alan, the serial # is E7-22342 bottom says 8E7-122
I guess that is for the v8 and wheel base?
Another plate has 8E-T6 on it.
I have nos door panel material. I wonder if you can still get nos
material for the seat?
Thanks for the bracket numbers.
I also like the idea of using the split back lark seats!
53commander HDTP
53 Champion HDTP
64 GT
Alan
10-19-2005, 12:41 PM
The nice thing about Stude's is they swaped around a lot of things, the seats are 2 styles, the solid seat out of the 4 doors and the split back from the 2 door. The only difference is the adjuster brackets. All 8E7's from 19,104 to 8E7-21596 use those brackets. But then again my book and experence only goes to the end of 63.
60Lark
10-19-2005, 01:02 PM
They also used the reclining split seats in 4-Doors
Studebaker Fever
60 Lark
51 Champion
Phil
