View Full Version : Defroster doesn't work
Blue 15G
10-13-2005, 07:16 AM
When I got my '54 Champion back on the road, the defroster wouldn't work. I replaced the dash switch. Didn't help. I bought a used defroster motor. I removed the old defroster motor from the car and hooked it directly to the battery. It wouldn't spin. Then I hooked my newly purchased used motor directly to the battery. It ran smoothly and quietly. Great!
I installed the used motor and it still doesn't spin when I hit the switch. [V]
Is there something obvious I'm missing? Bad ground somewhere?
When I turn the switch on, the ammeter does twitch a tiny bit to the discharge side, if that gives any clue.
I don't even need the defroster, but I like to have everything in working order on the car.
BRUCESTUDE
10-13-2005, 11:01 AM
DID YOU CHECK THE CONNECTION AT THE MOTOR FOR "POWER" WHEN THE SWITCH IS ON? IF THERE IS POWER, TRY A JUMPER WIRE FOR ANOTHER GROUND.IF IT IS THE GROUND, USE SOME GOOD STAR WASHERS ON THE MOUNT. BOLTS.
ALSO, IF THAT SQUIRREL CAGE FAN IS NOT ON THE SHAFT FAR ENOUGH, IT MAY BIND IN THE HOUSING.
I USUALLY DON'T DRIVE MY STUDES IN THE WINTER, BUT IT'S NICE TO HAVE THE DEFROST FOR THOSE RARE OCCASIONS,....OR HEAVY BREATHERS.
60Lark
10-13-2005, 11:38 AM
Are you sure the blower wheel has not been put in a bind during the re-installation of the defroster, I ran into a similar situation when I installed the defroster on my 51 Champion and had to make a couple of additional shims to gain clearance. This could be what caused the original motor to go bad.
Studebaker Fever
60 Lark
51 Champion
Phil
Blue 15G
10-13-2005, 11:53 AM
Thanks so much for the advice. I'll check both possibilities next time I get out to the garage.
10-13-2005, 12:32 PM
The fact that there's a small discharge registered on your ammeter shows that the motor's drawing power and the ground's good (ASSuming the switch or associated wiring isn't shorted somewhere). It may well be that you've got a bind on the blower wheel.:D
Blue 15G
11-13-2005, 10:26 AM
Well, I finally found time to get out to the garage and look at the defroster motor in the '54.
I put a test light on the wire at the connector near the motor, under the hood, and had power there. So I took the cover plate off the heating coil under the dash and found that the squirrel cage was somewhat stiff. This puzzled me, because I tested the motor before I installed it and it ran. Well, might as well pull it off again.
Then I remembered that I had another spare motor from a stash of stuff I bought off of a '53 parts car a few years ago. I found it, and the cage moved very freely. Then I did a test connection directly to the battery. It spun like Britney Spears on amphetamines. :D
I installed it, and I now have a working motor! ;)
The job isn't quite done yet, because I had taken off the old defroster duct hoses a long time ago, and when I tried to reinstall them I found out that the 51 year old paper/fiber (?) junk that they are made of doesn't stretch at all. Come to think of it, I don't stretch very well when I'm up under the dash anymore either, but that's another story. :(
I have one more question. I've read for years that sometimes you can restore a small electric motor by drilling a small hole in the dimple at the end of the motor, and squirt some oil in it. Have any of you ever done this with any success? If so, maybe I can get into the used defroster motor business!
Thanks again for your help.
N8N
11-13-2005, 05:01 PM
the hole-in-the-dimple trick works about 50% of the time, because there's two bushings. If it's the front bushing that's seized up that won't help you any at all. It's a PITA but I like to disassemble the motors and make sure the felts are thoroughly soaked with oil. Just don't get any on the windings, or if you do clean it off.
62 Daytona hardtop
11-13-2005, 06:40 PM
I usually have no trouble getting some oil on the bushing at the business end of these motors. If you use one of those little oilers with the extendable spout, you can do this without removing the blower wheel (which can be a bear sometimes!)
But I DO drill a little hole at the center of the little dome on the other end of the motor and inject a bit of light oil. Has worked every time for me.;)
