View Full Version : What weighs less ?
laughinlark
09-28-2005, 05:47 PM
I have a 63 Lark 2Dr that was a 6cyl car originaly. I think it is considered a custom model. Body tag is 63S F6 891. Looks likes the Red Tomato. I haven't weighed it but my guess would be 3200-3300 lbs. It has a 289 .40 over with flat top pistons and the thick head gaskets. I put a Isky cam in it and an Edelbrok 600 carb. The heads and everything else is stock down to the 3.31 rear end gears. Best ET to date is 15.07 @ 89 mph. I was wanting to build another engine about the same specs for an 47 M Series 1/2 ton short bed truck that is in pretty sad shape (rusting)in the back yard. I've seen a couple M Series trucks with Stude V/8s. There was one in Spokane. Is the 63 Lark lighter than an M Series with a V/8 ? [8D]
Thanks, Gordon
DEEPNHOCK
09-28-2005, 06:36 PM
My swag would be the pickup being lighter.
Thanks, Gordon
DEEPNHOCK at Cox.net
'37 Coupe Express
'37 Coupe Express Trailer
'61 Hawk
studegary
09-30-2005, 09:00 PM
The base weight of a 1963 Custom two door six is 2680 pounds. An equivalent model V8 would be 2940 pounds, but there is more difference than just the engine. I think that the truck would weigh more, due to the frame, but I don't have the weights here.
Chicken Hawk
10-01-2005, 09:17 AM
You are probably pretty close on the weight of your Lark. The Tomato weighs about 3350 depending on how much gas is in the tank. I have no idea about the truck weight but my guess would be it is lighter.
Ted
laughinlark
10-02-2005, 08:27 PM
The reason why I'm asking about weight is because its the cheapest way to go faster. :D There are a couple of trucks that run at our local drag strip that make you think WOW trucks arent supposed to run like that! One is a really cool 46 Chevy 1/2 ton that runs 11's. I was thinking it would be cool to see my 47 short bed Stude truck rolling down the strip with a Stude V/8. My truck is whole but rusty in spots. Its not like I would be gutting a cherry M Series truck. I think it would cut the wind as good as a Lark. Everything is in the thought process. My 12 year old is wanting a junior dragster also.[:0] She has a few years to go before she can run the Lark.[8D]
My daughter goes to every event that I run the Lark. She started chosing my ET's for eliminations based on my time trial. Can't start them to young about racing Studebakers.:)
Gordon
