View Full Version : Shock Absorbers
bekglm1
09-27-2005, 09:59 AM
Does anybody have a list of interchange shock absorbers for Larks? According to my stude factory manual, almost all of the Lark models had similar Gabriel shocks. I would like to see a list of interchange Monroe, Bilstien, or other leading brand of shock absorbers that can be used on various Lark models.
Please send your replies to bekglm1@aol.com
Thanks
JDP
09-27-2005, 10:07 AM
Try your local Autozone, they list the Gabrial "Classic" gas shocks, about $15.00 each.
64 R2 4 speed Challenger (Plain Wrapper)
63 R2 4 speed GT Hawk
60Lark
09-27-2005, 10:15 AM
You can log onto Autozone.com and follow the prompts to get the correct part numbers for you Lark. When I got shocks for my Lark they did not have them at the store but they had them in 2 or 3
days.
Studebaker Fever
60 Lark
51 Champion
Phil
Alan
09-27-2005, 01:25 PM
If you really have your heart set on Monroes and have the shocks that have a 3/8"-24 thread stud on the bottom and a 7/16"X 2 1/4" loop on the top you can use Monroe 37074, for heavy duty use the 37192 with parts pack p120 and p171, with this you have to press out your old sleeve and install it in the new one, or the Limited Edition no. LE 10060 and fab yourself a sleeve of 7/16" ID X 3/4" OD X 2 1/4" long. The parts packs may have the pieces you need in them but I always make new pieces out of stainless barstock so I don't buy the parts pack.
N8N
09-27-2005, 05:15 PM
got some numbers here
http://home.comcast.net/~njnagel/files/interchange.pdf
Gabriels can be ordered at AutoZone, if you are looking for more performance I believe you can still get Konis for the Camaro apps that work with a little modification. I haven't tried the Camaro ones, I am running the Gabriels on my cars. They are a straight bolt in and seem to work pretty well.
I am not aware of any current shocks other than the numbers I have listed that are a straight bolt in.
62 Daytona hardtop
N8N
09-27-2005, 05:18 PM
oops, I see the Camaro listings got cut off when I did the last conversion to .pdf. I will have to fix that... ISTR that it was a 1970 Camaro that would work? both front and rear for 63-up cars but don't quote me on that. You have to press out the upper spacer on the rear and reuse your old one, and press out the lower mount on the front and reuse your old one. Like I said I haven't tried it though.
62 Daytona hardtop
Alan
09-27-2005, 05:47 PM
N8, the Koni's are Pn. 8240-1012 for the rear and 8240-1011 for the front at $98 a piece.
prager
09-27-2005, 07:00 PM
J.C. Whitney has them..Ask for their hard to find shocks..I just got my rears from them..no problems..Gabriel classic gas..
60Lark
09-27-2005, 11:15 PM
I just looked up my AutoZone receipt the shocks I put on my 60 Lark. They are Gabriel Red Ryder Classic gas shocks - Part #82087-front shocks and Part #82151-rear shocks - $14.99 a piece.
Studebaker Fever
60 Lark
51 Champion
Phil
N8N
09-28-2005, 05:05 PM
I just checked my notes - it is 1970-81 Camaro shocks that may be modified to work. I have never tried this, I think I got this nugget of info from an old Datson book.
HTH
62 Daytona hardtop
