'60 Lark Antenna & mirrors location
  • '60 Lark Antenna & mirrors location
    Does anyone have either templates or can supply measurements for locating the radio antenna and Stratoline mirrors for a '60 Lark?
    Thanks for any help!!
    Rob
    David Mottle, SDC librarian should have these.
    Miscreant adrift in
    the BerStuda Triangle
      Miscreant adrift in
        Does anyone know if some of these templates have ever been scanned for posterity? I do have access to a large format scanner...
            I believe Dave only has originals. You might contact him with your suggestion/offer.
            1959 DeLuxe pickup (restomod)
                I am sure that the crank-up antennas and probably the manual ones all came with the template for drilling the hole. It goes in the left fender AND cowl, it has no more than 1/4 in. clearance to the inboard side and rear of the fender so that it goes down into the door post.
                However, I would not think that the mirrors would even have a template, because it is completely owner preference as to the owners height etc. as to where to mount it.
                But then again not knowing that, if by some rare chance someone ordered the mirrors factory mounted (as in FACTORY delivered) MAYBE they had a average spot in mind to mount them. It would be very rare however that they would be factory mounted, if you see an AC# mirror or any accessory on a build slip like wheel covers, seat belts it should be prefixed by an "X" meaning loose in the trunk. Mirrors were dealer installed at point of sale. [:0]
                Studebakers Northwest
                Ferndale, WA
                  Ferndale, WA
                    Amen on the mirrors. I think they ended up mounted wherever the owner wanted them.
                    Look at this picture and see where mine were originally mounted from the dealer. Look hard--they are right in front of the antenna on the top of the fender:
                    ________________________
                    Mark Anderson
                    1965 Cruiser
                      Mark Anderson
                      1965 Cruiser
                        Regarding the mirrors, If you mount them on the doors, they should be forward of the vent window far enough so that your not looking "through the vent window post" when you look at the mirror. They should also be far enough forward that the vent window can fully open. Someone did that to my Commander and it really messes with your vision when you look through them
                        John
                        1950 Studebaker 2R5 with 170 turbocharged
                        [img=left]http://i158.photobucket.com/albums/t102/PlainBrownR2/DSC00003.jpg?t=1171152673[/img=left]
                        [img=right]http://i158.photobucket.com/albums/t102/PlainBrownR2/DSC00009.jpg?t=1171153019[/img=right]
                        [img=left]http://i158.photobucket.com/albums/t102/PlainBrownR2/DSC00002.jpg?t=1171153180[/img=left]
                        [img=right]http://i158.photobucket.com/albums/t102/PlainBrownR2/DSC00005.jpg?t=1171153370[/img=right]
                          John
