View Full Version : Testing a starter?
iceman_t1
09-04-2005, 06:49 PM
I got the starter off the car. It's a Delco-Remy 12 volt starter. I would like to test the starter off the car before I put everything back. What is the easiest way to test a starter?
Proud owner of a 1956 President Classic
JDP
09-04-2005, 07:43 PM
Hook a postive cable from the battery, touch a negitive to the case and away it goes. (Be care that it does not roll off the bench from the start up torque.)
64 R2 4 speed Challenger (Plain Wrapper)
63 R2 4 speed GT Hawk
Transtar60
09-04-2005, 09:30 PM
I usually test them on the floor/ground keeping one foot on it to keep it from spinning from the torque.
iceman_t1
09-04-2005, 09:31 PM
hmmmm, I need to get a battery...
Dwain G.
09-04-2005, 11:16 PM
A good starter will reach its rated free-running rpm in about 1 second. Don't let a starter spin at top rpm for more than about 3 seconds. That starter is rated at 6,900 rpm, and you risk throwing a commutator segment or doing other damage.
Dwain G.
iceman_t1
09-04-2005, 11:28 PM
Dwain, Thanks for the tech info. I'll just put it back together and test it under load. It spins freely so I'll bet it will work when it's all back together.
curt
09-05-2005, 10:42 AM
Would it not be a bad idea to lube the bearings and evaluate the brushes while the starter is out?[?]:)
