Tom,
Can we further discuss the use of this Honda alternator to replace the wretched Prestolite unit (ok, its 40 years old so maybe wretched isn't quite fair)? Do you know whether the Honda 35 amp alternator you mention as being a swap for Larks and Hawks can be used on the Avanti? I know the Avanti Prestolite alternator is a 40 amp unit, but how much difference does that make? On a non-air conditioned car I wouldn't think much(?). What about the regulator on the Avanti (I have a "fancy" electronic regulator from Dave Thibeault and don't want to change it), it is only going to sense a maximum of 35 amps in lieu of 40 but I can't see that as an issue--but I may be oversimplifying things. Will the Honda alternator bolt up to the Avanti style bracket? If I carry a spare Honda unit can it be swapped out on the road if the Prestolite unit gives up the ghost? The wiring as I understand you is quite similar to the Stude set up (?). Somone asked if the Honda style pulley is still used or if the Prestolite pulley needs to be swapped--that alone could make it difficult to do an alternator swap on the side of the road. My Presolite unit ripped out all the spokes between the front bearing and the case a few years ago and at that time I had it welded. Also one of the brush holders was about shot and I made up a repair using a piece of plexiglass to support the brush holder in the case, but I'm not too trusting of either of these repairs. Thanks for the help.
wagone and the old R2 Avanti
