View Full Version : engine knock, compression check results
bing kunzig
07-28-2005, 11:58 AM
Thank you all for your input. Let me know what you think about how these figures may or may not relate to the knocking sound:
#1 140 #3 135 #5 145 #7 145
#2 155 #4 130 #6 140 #8 140
Mike Van Veghten
07-28-2005, 01:39 PM
1. Did you have the throttle blocked open? That can make a big difference.
2. Engine hot or cold?
3. With the exception of the open carburetor screwing with good readings, those numbers aren't bad. While they should be a little higher, they are fairly even.
4. Another way of ring inspection (without a leakdown gage set) is put some oil in the cylinders, spin the engine to distribute the oil better, then take another compr. reading.
whacker
07-28-2005, 04:27 PM
Well, I guess that pretty much shows that I am full of beans! Your compression is fine, consistent with all cylinders. Your knocking sound is something else.
07-28-2005, 07:59 PM
bing,
with the engine running, (using a pair of plastic pliers that are made for such), pull one plug wire at a time and see if the knock quits on any particular cylinder as it's wire is disconnected.:)
curt
07-28-2005, 09:10 PM
That sounds like good advice, pull one wire , from Mr. Biggs. Wrist pin and what else would this help diagnose?
N8N
07-29-2005, 05:46 AM
Wrist pin, loose piston, or rod bearing. (could be something else I guess, but that's what the "pull the spark plug wire" test will tell you)
62 Daytona hardtop
bing kunzig
07-29-2005, 12:44 PM
Thank you all. I think what I will do is have it checked out by my local Studebaker Service Center in Long Beach. I am taking it there anyway next week to have a power brake booster installed. Leave it to the experts.
buddymander
07-30-2005, 07:56 PM
I would take a piece of garden hose aboaut three feet long and hold it up to my ear and the other end down by the edge mof each cylinder. I kinda suspect numbers three and four for a wristpin knock or a piston slap contributing to the lower compression in those two cylinders due to piston wobble or lower piston height due to the excess wristpin clearance.
studegary
07-31-2005, 12:14 PM
I usually use a long screwdriver for a makeshift stethoscope.
curt
07-31-2005, 02:12 PM
Keep clothing ,shirt sleeves, tie, etc out of the fan belt when under a hood with engine running. Even long hair could get caught. I hit a finger once on a fan blade, I was in luck, no big damage.
PaulDriver
07-31-2005, 04:12 PM
held to the occipital bone?
studegary
07-31-2005, 07:35 PM
No, the large end pressed to my ear. (I think that it would be impossible to see where the other end of the screwdriver was if I held one end to the base of the back of skull.)
