I recently purchased a nice '57 Silver Hawk with about 5000 miles on the restoration. After it is warmed up, there is a distinct knocking sound that keeps pace with the RPMs. Doesn't have that lifter type sound. What are the likely causes?
engine knocking sound
There's the off chance it's the fuel pump. There's a chance it's a flex plate going bad (is it an automatic?) - but it's it's a dull knocking sound, it might be a connecting rod bearing OR a broken piston. What's the oil pressure look like at speed? Has it changed of late?[}]
1963 Daytona project FSNo deceptive flags to prove I'm patriotic - no biblical BS to impress - just ME and Studebakers - as it should be.
The symptoms you describe are those of a blown head gasket between the internal cylinders, such as between 1&3 or 3&5 or 2&4 or 4&6. What sounds like a knock is the hot gas going from one cylinder to the adjoining one. Oil pressure will stay OK, as long as you don't breech an oil passage and you won't see any coolant in the oil or oil in the coolant. Get a cheapo stethescope and listen between the cylinders on both heads to determine which side it is on, and which cylinders are affected. All that should be required if you get to it right away is a new head gasket (check for flatness before you reassemble). If you let it go too long, you will be looking at doing both heads and probably planing them both as well.
whacker - what you say may be true. But you'd think he'd be telling us that this thing is running rough if that were the case.[}]
Bing, can you run a compression check? [?]
No, this kind of blown gasket doesn't cause the engine to run rough. It will cause it to burn oil tho. All the gas is still kept within the heads and cylinders. It is usually caused by not re-torqueing the head bolts, or not torqueing them enough, or not getting sealing compound between the leaking cylinders. A compression test will definatly determine if I am right. You will find two cylinders next to each other with very low, but equal compression.
I've been thinking about this, and the possibility exsists that I could be wrong (hard to believe, I know). Let's look at this logically. Here are the clues we have: engine has a recent (5000 mi) rebuild. Sound (knock) occurs after warm up. Sound keeps pace with engine RPMs. Doesn't sound like typical lifter noise. Oil pressure is good and stays good. Here are the assumptions: engine doesn't seem to loose power. Engine isn't overheating. Gas consumption is normal. Not a noticable vibration.
OK. The sound must be engine related, so we eliminate brakes, U-joints, transmission, other running gear. What happens when the engine warms up? The thermostat opens. The oil, if it is single viscosity, thins out, if it is multi-vis it thickens. The rubber belts stretch.
Just because it dosn't have the typical lifter sound doesn't mean it isn't the lifters - it could still be the lifters.
It could be that the water pump or the fan flexes or rotates off center when the thermostat opens.
It could be that the distributor has worn bearings that allows it to tap when the oil thins.
It could be the generator is loose on the bracket and rattles when the belts expand.
It could also be a blown head gasket between two adjacent cylinders.
My engine mechanical knowledge isn't that great, but why could it not be a rod bearing? I know that sound can go away when under load, but it would increase with rpm--right?[:I]
________________________
Mark Anderson
1965 Studebaker Cruiser
