View Full Version : wheels for Avanti
charley norton
07-12-2005, 11:54 AM
I'm looking at the torque thrust D wheels for my Avanti but don't know how wide a rim I can use. I'm thinking I can use 7" and that my bolt pattern is 4.5". Can I get wider than that without hurting the fenders or hitting the suspension? How about a taller than stock rim? What looks good. I've got the rotating hubcap thing and don't like hubcaps anyway
63 R2 Avanti
N8N
07-12-2005, 06:06 PM
7" is pushing it, I know that you can fit them on a C-K but it's tight. I would say stick with a 6" rim and a little bit of offset if you can (1/4 to 1/2") and you *should* be OK.
Maybe someone can comment about fitting 7" wide wheels to an Avanti, I haven't tried it so I can't give you a definite answer either way.
62 Daytona hardtop
Alan
07-12-2005, 06:29 PM
I haven't put the TQ-Thrust D's on my Avanti but I have put a number of different steel wheels on.The 7" steel rims made by Pioneer and Keystone Custom mags. will fit with a 4 3/4" back space but on a 235X60X15 they will rub on a full lock turn either way at the front of the upper a arm where the zerk fitting hangs out. I solved that by putting a 1/4x28 plug in the hole and putting the zerk fitting in when I grease it.The TQ-T is thicker than the steel rim so I would say no more than 4 1/2" back space with it.But then watch the fenders.
benny_64
07-21-2005, 09:42 PM
i am not too sure how much the rearend on an avanti differs from a lark but i fit a 9" wide 17" tall wheel on the back of my lark with plenty room. the front wouldn't take more the 6 or 7.
slow64
1964 lark daytona
bd_marks@yahoo.com
Danarchy
07-21-2005, 10:19 PM
I have a set of 15x7 Torq-Thrust-D's (4 1/2" backspacing) and they Rub on the front of my LARK wagon (with stock suspension). I am going to go with a 15x6.
Dallas,Texas
Alan
07-21-2005, 10:28 PM
What rubs and where? Look and see and let everyone know.
Danarchy
07-21-2005, 10:45 PM
Inside front fender maximum turn. Top of wheel hits(rubs)225/75-15
Dallas,Texas
Alan
07-21-2005, 11:53 PM
That's a tall tire I run 235/60/15.
charley norton
07-22-2005, 06:08 AM
Hey Alan, that 235\60\15 tire you use. Is it on a 15x6" rim? Or does it need a 7". Thats a size I used on a barracuda I used to have and really liked the looks of it. But I'm afraid to use a 7" rim. Also, is the tire height close enough to factory where the speedo is close to accurate?
63 R2 Avanti
charley norton
07-22-2005, 07:32 AM
I guess I'm wondering that if I use the torque thrust d wheels, I need a 15x6 wheel with a 4 1\2 backspace and a 4 1\2 bolt pattern using the 235\15\60 tires, I should be ok and still have an accurate speedometer.
63 R2 Avanti
Alan
07-22-2005, 11:40 AM
Charlie, the 6.70's I checked out ran from 27 1/4 to 27 1/2" and the 235/60 R15's were 26 1/4". The rims I run are steel 10 hole chrome 15x7 with a 4 3/4" backspace. but on the rear I run 275/60x15's on the same rim. These are 28" tall. You have to lift the body slightly to get them under the fender and don't take a turn fast with a couple of people in the car unless you want to hear funny rubbing noises and smell rubber being scraped off numerous places.
charley norton
07-23-2005, 07:53 AM
Alan, do you have a picture of your car you can email me? I'd like to see what your tires and wheels look like. Or any other Avanti with aftermarket wheels and tires that someone has.
Thanks Charley
63 R2 Avanti
Alan
07-23-2005, 10:26 AM
OK Charlie, I will take some pics. Although my car is sitting higher right now because I have a 4.3 Chevy V6 that is only about 300 lbs. in it. And have not played with the springs yet, because when Red Roberts gets around to the bellhousings the Avanti engine is going back in.
What area are you near? If you are around the L.A. area I could help you in your quest.
charley norton
07-23-2005, 01:53 PM
If you mean LA as lower Alabama, We're neighbors!!
63 R2 Avanti
Alan
07-23-2005, 02:07 PM
Only about 2,000 miles, that's allright Charley I'll get you the pictures.
charley norton
07-25-2005, 06:50 AM
Thanks, Alan. Hey, have you ever heard of the factory rims haveing problems with the lug nuts pulling through the rims? Theres not a lot of meat there and it looks like a good curb hit would knock the wheel off. Hopefully, I won't have to worry about this long.
Charley
63 R2 Avanti
Alan
07-25-2005, 09:42 AM
Old wives tales I have never seen a rim damaged like that myself. And how often do you smack curbs anyway?
charley norton
08-02-2005, 07:04 AM
I found some Torque thrust D(4.5 bolt patt.) rims but not sure if they'll work. They are 15x7 for front and 15x8.5 for the back. They only have 3.5" backspace. Will that make them stick out from the wheel well??
They have a set of tires on them. 2x225\50\r15 for the front and 2x245\50\r15 for the back. I'm pretty sure the front tires won't work, but what about the back?
Thanks
Charley
63 R2 Avanti
Alan
08-02-2005, 09:53 AM
Charley, The fronts would work if you changed tires. but the rears would be a mess it would look like a *** car with reverse rims. The biggest rim I have ever run was a 15x8" with a 5 3/4" back space and 275x60's and they rubbed on every turn and bump, both against the springs and the fender.
