View Full Version : Avanti Parts for Bonneville car
64Avanti
07-12-2005, 12:15 AM
I am looking for some parts for my Avanti for Bonneville.
I need a decent center pivot shaft. I started working on the suspension and found that this part is severely corroded and needs to be replaced. Normally the bushings are shot and the shaft is not too bad. If anyone has one they would be willing to donate I would appriciate it. If not I would be willing to pay a reasonable price. New ones are about $95.
I also need a pitman arm and reach rod for a non power steering Avanti. The pitman arm is part number 1557161. I should also be able to use an arm from a Hawk or Lark (59-60 only) There were two part numbers 1551387 and 1541938. I don't know the difference between the two. It is most likely the location of hole for the reach rod ball joint.
David L
07-12-2005, 07:39 AM
I have just the pitman arm - no reach rod. It has the hole for the ball joint in the mid position.
Mike M.
