View Full Version : Boiling gas fixed
charley norton
07-10-2005, 08:41 AM
Just a note to tell everyone how much I appreciate the advice. I would have never figured it out. My return line was the problem. I blew it out and the glass filter is and stays full for the first time since I owned the car! No more boiling\bubbling gas in the filter. I also changed the flapper valve and put a better quality carb base gasket on it and have noticed a big difference. Although now it seems the timing needs to be set again. Thanks again
63 R2 Avanti
Sonny
07-10-2005, 12:15 PM
63 R2 Avanti
That's great to hear Charlie! Just one question though, when you say "flapper valve", are you talking about the heat riser on the R/H exhaust manifold?
Sonny
http://RacingStudebakers.com
charley norton
07-10-2005, 05:29 PM
Hey Sonny. No, I was talking about the spring loaded flapper thingy in the air box. Now the only problem is the air box blew off the carb., stripping the threads inside the carb. I don't think it will be too tough a fix. Anyway, back to the hurricane!
63 R2 Avanti
