I have to replace the cam lever shaft seal in my SL steering gear box(63 Hawk). What problems will I have getting the old seal out after I get the pitman arm off? Will I have to remove the starter?
I hate to be the bearer of bad news, but I don't see you getting the pitman arm off in the car. If you do, more power to you...
62 Daytona hardtop
I have removed the pitman arm from the steering box on a '64 Hawk, with the engine in the car......was putting the power steering back on the car that the previous owner removed. It can be done!
I do remember that the center 'bolt' on the pitman arm puller was too long and interferred with something, so I had to get a short bolt with the same threads. After that, it was not hard at all.
Hope this helps.
PaulPaul
Winston-Salem, NC
The output shaft on the steering box isn't tapered. I used a shorter bolt in the puller and reversed it so the head was against the end of the shaft. Between engine oil leaks and the bad seal on the steering box, everything was well lubricated; and the arm came off easily.
Mike M.
