View Full Version : how do you put car on blocks
pete
03-07-2007, 02:38 AM
does anyone know the correct way of putting the stude on blocks for long storage ; do you place the blocks so the car rests on the main chassy so the sp rings flop down or wat is best thks for any help . pete
03-07-2007, 02:47 AM
Well pete, first off, ya gotta have a jack![}:)] Then, yes, support the frame and not the suspension. At least - that would be MY approach.;)
Miscreant adrift in
the BerStuda Triangle
03-07-2007, 02:54 AM
I don't know which is best, but probably the most common method is to put jackstands under the front crossmember where it crosses the frame and on or near the front of the rear spring mount. Using that method the springs do not take a "collapsed" set from long storage. That does put more stress on the front end of the frame from engine weight however. Maybe not as big a problem if you have a lighter 6 cyl. car.
Studebakers Northwest
Ferndale, WA
pete
03-07-2007, 03:03 AM
well on my 63 lark the front suspension is stuffed eg. front springs are shot as well as all the bushes etc the back is all good the car has very high miles about 300000 miles on the clock and had 22 owners so the car needs fixing up its a usa cruiser right hand drive bought over to nz
03-07-2007, 04:10 AM
Well then, in that case the under the outer ends of the front lower control arms and outer ends of the rear axle tubes method will also work fine, just put it high enough to have a inch or so clearance under the tires.
Ferndale, WA
DEEPNHOCK
03-07-2007, 07:07 AM
Blocks? No!
[u](Cinder blocks, cement blocks, concrete blocks... NEVER!)</u>
Jackstands.. Yes!
Jackstands under the rear spring mount pads under the axle tube.
Jacksands under the front a-arms out toward the spindle.
Weight of vehicle should rest on the suspension.
Spray a light oil on the front shock rods to prevent corrosion.
Grease the suspension when putting it up there.
In fact, repack the front wheel bearings now, so you are ready to go in confidence when you bring it out.
Adjust the brakes too. Nows the best time.
http://i77.photobucket.com/albums/j54/deepnhock/Jeff%20Rice%20Studebaker%20Pictures/1937StudebakerCoupeExpressJeffRicee.jpg
DEEPNHOCK at Gmail.com
Brooklet, Georgia
'61 Hawk (project)
John Kirchhoff
03-07-2007, 10:06 AM
Well Pete, here in the states, every redneck knows how to put a vehicle up on blocks because they always have at least one in the yard parked in that manner. Since you're in New Zealand, I suggest you take a plane flight to Tasmania and look around because my Aussie fiancee says the "Tazzies" are southern hemisphere rednecks!
03-07-2007, 12:01 PM
Wouldn't you hafta set the "blocks" ON TOP of the car - down under?[:0][:o)]
OH! And on the serious side, I'd fill the gas tank and add some of that gasoline stabilzer stuff. Drain the cooling system - and this includes the block drains as well.
Miscreant adrift in
Mike Van Veghten
03-07-2007, 02:48 PM
Nuthin wrong with putting good stands out as far as possible (near the springs) on the rear axle housing.
As for the front, be very carefull if you put the stands on the lower control arms. Put the stand right where the pocket for the spring ends...to the outside of the car. Then be carefull when you lower it to make sure they don't slip around.
On the other hand...there's absolutly nothing wrong with putting the stands just behind the control arms on the frame (chassis). When I put a car up for any length of time, I also put a stand under the center of the front cross member for full frontal support.
I don't particularly like having the car sit fully on it's springs here in sunny So. Cal. It wouldn't take much of an earth quake to vibrate the car right off the stands! A solid support is better in my opinion.
03-07-2007, 06:29 PM
I know folks have been putting cars "up on blocks" since...well, since there were cars. I'm not sure I've figured out WHY, however. What does it do good for? The suspension? If it was still being driven around, it would be on the ground...same as if you stored it on the ground. The tires? If you store it for 5 years or so you're going to need new tires anyhow due to age. I dunno. [?].
Seems to me that if it was stored on the ground, you'd be more tempted to fire it up and drive it every now and then.
DEEPNHOCK
03-07-2007, 06:40 PM
I remember way, way back in high school......
There was this time I was working on my Hawk and it was up on jackstands... My girlfriend came over and we were, uh, listening to the CONLRAD radio (WCFL AM 1000 in Chicago!) and during the one favorite song, the vibrations knocked the one jackstand over and the car fell off the jackstands.
No one was hurt in the incident, but I remember being told the earth moved (or something like that;))
quote:Originally posted by Mike Van Veghten
&lt;snip&gt;
Brooklet, Georgia
'61 Hawk (project)
rockne10
03-07-2007, 09:53 PM
quote:listening to the CONLRAD radio One of these days someone will post the question,"Why does my radio have little triangles on the dial at 640 and 1240." Will they believe it's all about nuclear destruction?
pete
03-08-2007, 01:40 AM
thanks for all the susjestions except the red neck bit you see ive never put a car on blocks before for storage so i was just asking in case there was a wrong way of doing it and ive never been to taz
