View Full Version : need help identifying a part
borninthe50s
06-16-2005, 11:40 PM
Hi, we had Studebakers in the 50s and 60s. I've got what I think is a transmission from one of the vehicles. It was removed, then probably replaced, but never rebuilt, and may still be in working order. The part number is DG 20 505 P N2. The housing is cylindrical in shape with a gear shaft protruding from one end. I would be surprised if it was NOT a Studebaker part.
Thanks!
borninthe50s
06-18-2005, 11:00 AM
OK I'm getting the sense that the trans I have is a precursor model to the DG 250?
I will say this: my mother used to stall out our Studebaker bigtime, then she'd flood the carbuerator trying to crank it back up again and we'd sit and sit. I don't really blame the car;) unless the idle was set too low and it would just cut out; or maybe the brakes had something to do with it.
The Stude I remember riding in (back seat)was a 4 door sedan black in color. There were no seat belts but we kids hung on to a strap that was affixed behind the front passenger seat. Hung on, of course, when the vehicle wasn't stalled out.
I have never driven a Studebaker :( but I am a qualified Bentley driver!
06-18-2005, 12:03 PM
Well, most 4-doors had the "robe rail" across the back of the front seat (ones that would have had a DG tranny in them anyway)
Do you remember if the rear doors had vent windows in them? The top-of-the-line 4drs ('51-2-3-4 Land Cruisers or '55 President sedans)would have had those rear vent windows. The 51 thru 54 LCs & Commanders would have used a DG-200 transmission. Any chance you overlooked a zero behind that DG-20 ??? '55 Presidents would have come with the DG-250M variant of this tranny line. After '55, Studebaker dropped the DG line save for '56 Champions and some truck applications.;)
borninthe50s
06-18-2005, 01:41 PM
Thank you Mr. Biggs!
I've just taken another look at the trans. I was looking at one side and turned it around to find this plate:
Detroit Gear Div. Borg-Warner Corp. Detroit Michigan USA
Model DG 200
Serial No. SCO 137178
Is this a 'less desirable' transmission? I wonder if it was replaced with a DG 250. The transmission in question has been kept indoors and has no visible rust. I had to take a toothbrush & WD40 to clean off the serial plate & stamped numbers. I might have some other little doo-dads around.
studegary
06-18-2005, 02:13 PM
Yes, a DG 200 is less desirable than a DG 250, but desirable is a relative term. It is getting hard to find any of this series of transmissions in good shape. There are plenty of cars out there with DG 200s whose owners would be glad to get the transmission.
borninthe50s
06-18-2005, 03:47 PM
I can't verify its condition internally. the shaft does not move freely--I tried to turn it by hand. Perhaps it takes the action of a drive train to make that happen-- plus it has been sitting for ~40 years. I'll take another look at it and also try to find records of which model Studebaker it came out of. Thanks for everyone's advice & help so far!
___________________________
I figure this trans came from a 52 commander convertible-- there is a draft of a letter my dad sent to Studebaker Corporation South Bend 27 Indiana. His complaint about the transmission was that the reverse feature failed, so he had replaced the transmission-- otherwise everything about the transmission was OK. I'm guessing the problem was due to linkage & possibly oil pressure failure.
My transmission has no fluid in it aside from a small amount on the bottom visible by flashlight.
I've also found two manuals:):
1951 Passenger Car Shop Manual
Studebaker Automatic Drive Shop Manual covering 1954 Champion model 15G
gordr
06-18-2005, 10:05 PM
Hi there, '50s guy.
From your description, I'm guessing that the torque convertor is not present, when you say you tried to turn the shaft. If you look closely at that shaft, you will see an outer splined shaft, and a smaller splined shaft inside it, projecting a bit further out. The outer shaft is the stator shaft, and is fixed; it will NOT turn. The inner shaft is the one that should turn.
Sounds like this is a "take-out" transmission, and that it may well have been taken out because of some problems. But if it has been stored in dry place, it could well be rebuildable. A fellow in another thread is looking for a DG 250, but he might accept a DG 200, or possibly the DG 200 could be rebuilt and upgraded to DG 250 specs.
I would definitely NOT throw it away.
06-18-2005, 10:16 PM
Regardless of what variant you have, the sad fact is that any transmission mechs that ever got familiar with the DG trannies are retired or have forgotten most of what they ever knew about the units. The few that STILL work on them are fading fast.
You could assume that one automatic tranny is just like another so far as a "technician" would be concerned. But that would be a way erroneous assumption. Most of today's tranny shops won't even LOOK at a DG. They have to feel like they know what they're dealing with and they're gonna have to stand behind thier work if they were to take on such a task.
The DGs were different in many ways from modern trannies. Sure, the principles are the same but have you ever seen the guts of one spread out? It takes someone who REALLY knows the DG units to have half a chance at taking one apart and having it work right when they get it back together.
Add to that that the pool of parts is dwindling as time goes on and it's doubtful that anyone will step up to make any new parts. It would be a money-losing venture even IF they could engineer the new pieces to the specs and quality of the original stuff.
Then throw in that it requires some special tools to handle one of these in an efficient manner - most shops won't have them and can't get them in this day and age.
I've got 3 DG trannies out in the shop at the moment. You can't turn the input shafts on any of them by hand, so I assume that that's normal.[:I]
It was a marvelous tranny for it's time. Fact is, even tho Studebaker co-designed it for their own line of vehicles, Studebaker abandoned it to use a cheaper automatic in a move to save money. After that, a relative few units were used in some foreign cars, but it was a trickle compared to when Studebaker was using them.
borninthe50s
06-19-2005, 02:31 PM
Thanks for your comments. This trans isn't going to hit the scrap pile, yet. Those of you who'd like to trouble shoot the possible problem might be able to determine whether it was an internal or external problem. I think it may have had to do with oil pressure--
in looking at the manual hydraulic oil pressure (or lack thereof) appears to control the reverse function of the trans. I don't know the mileage on the vehicle but the letter was written in 1963, and the '52 Commander Convertible was most probably purchased 'used'.
from my father's letter:
failure of the present (transmission) was as follows: In backing up slowly to go home, the car went roughly into reverse. I thought I might have backed up against a stone or something so went forward and backed again and headed home with no further questioning of the reverse. The next time I got in to use the car again there was no reverse.
In the case of the first transmission I checked the shuttle valve and interlock valves and the springs seemed to operate freely without sticking. I figured it was probably in the reverse freewheel unit so I got another transmission.
he goes on: some of your experts might be able to pin point the trouble and tell me what parts to replace and where I might get them--remembering that everything works OK but no reverse.
Very truly yours---
(Dad)
So can this transmission once again function properly? I wonder!
06-19-2005, 03:29 PM
Sure it could function again. With whatever expertise and parts are required to recitfy the problem. Have you got a car in mind to fit it to[?]
At the very least, it might be cannibalized to provide parts for another like unit. I've got a couple of DG hulks here that I took on just for that reason. Someone was gonna toss them because they found a working unit to use instead of addressing the expensive repair work of one that had a problem or the unit had come out of a car that had been cusstomized.[8] People just bring Stude parts here because they don't have the heart to toss them. [}:)]
borninthe50s
06-19-2005, 03:39 PM
Mr Biggs, where is 'here'?
If I had the 'rest' of a restorable 'like' Studebaker I'd keep the transmission myself;)!
I live in the Washington DC metropolitan area. I've had occasion to chat with the local Studebaker club members at car shows but it has been a while.
An aside: there was an auto dealership in Damascus, Maryland-- for some reason I recall this place had quite the inventory of warehoused Studebaker parts-- this was about 15 years ago. Can anyone confirm my recollection?
06-19-2005, 06:32 PM
I'm about as far west of you as one can get without getting saltwater between your toes.:D
A warehouse of Stude parts? Oooooooooh - I'm salivating! Too far away tho.
I had/have a lead on a stash of them in Indiana but the ex-car dealer that has them (ex-Chrysler dealer) won't even talk about selling them. So they just collect dust in an old hangar. I figure, he'll croak and the kids'll toss all that old "stuff" that dad's kept for years.[xx(] It's happened before![V]
studegary
06-19-2005, 08:15 PM
It has been 25 years since I remember working on the internals of one of those DG transmissions. The type of reverse function failure that you describe sounds very familiar for these transmissions. It is usually caused by something relatively easy to repair. The gasket in the valve body blows out at the reverse function section. A new valve body gasket and fresh fluid normally repairs the problem. I have used Studebaker parts to repair a Jaguar transmiision. The Studebaker parts were easier to get and cheaper than Jaguar parts. The gasket that I refer to is the one internal to the sections of the valve body, not a gasket where the valve body mounts in the transmission. I hope that my memory is correct. If you look in your transmission manual, it will probably be clear.
borninthe50s
06-19-2005, 09:02 PM
Thank you all for your advice. Yes, I've got the manuals but its waaay better to get LIVE TECHNICAL HELP! even though I don't have reason to do anything with the transmission other than let it lay around in my basement for another ten years. I guess I could look for a Stude on the cheap with a failed transmission but BODY, interior, electric & mechanical all in great condition-- no rust, of course... oh yes, all original... Just needs a transmission and a gasket. Sounds real simple.
Maybe I'll schlep it up to Hershey this autumn now that might be fun.
thanks again
borninthe50s
06-21-2005, 12:22 AM
The type of reverse function failure that you describe sounds very familiar for these transmissions. It is usually caused by something relatively easy to repair. The gasket in the valve body blows out at the reverse function section. A new valve body gasket and fresh fluid normally repairs the problem. The gasket that I refer to is the one internal to the sections of the valve body, not a gasket where the valve body mounts in the transmission.
studegary, I'm trying to visualize this without having a trans mounted on a Studebaker, and me standing next to it all. If the fault was in the gasket (the one you suggest replacing!)where exactly would that be... were there to have been a 'leaky' gasket... at a 'high point' in otherwords, not low enough to the ground, physically speaking, to cause egregious loss of fluids due to gravitational drip... unless under pressure? ouch, this hurts so bad especially cause I'm tracing the fault that my father apparently overlooked.
I guess it might be clear to SOME people, but maybe just not to my father or my brother;) of course that is only if I am correct! and its easier being correct without having a need to fix a vehicle so that you can once again drive it. At this point in time I am not subjected to the same type of fault tracing analysis that my dad & bro were in 1963---trying to get it back on the road ASAP. As Studebaker Drivers (can't claim to be ONE of those) I am sure you can all sympathize with their former plight!
studegary
06-21-2005, 12:45 PM
I am referring to a gasket in the valve body. It is internal to the transmission. It can not be seen or accessed from the exterior of the transmission. When it leaks, it does not leak to the exterior of the transmission. A small spot of the gasket "blows out" causing the loss of pressure necessary to activate reverse.
borninthe50s
06-22-2005, 01:23 PM
I have a feeling it was gasket related. There WAS a leak: perhaps they overfilled the trans or else there was a fault with the gasket AFTER they put the transmission on. Too great a volume of fluid under pressure WILL blow a seal. I think this was the problem. I guess I should ask my brother! Then I'd find out what happened to his convertible, as well.
06-22-2005, 06:57 PM
That DG tranny is not a sealed unit that could "overpressurize" and blow a seal from excess fluid volume.
studegary
06-23-2005, 01:01 PM
I agree with Bob/MrBiggs. Overfilling would have nothing to do with it and you can't overpressure it. I am referring to the failure of a small section (usually 1/4 inch) of gasket in the valve body.
borninthe50s
06-24-2005, 01:43 PM
this would have caused an engine oil leak, decreasing the amount of oil pressure necessary to activate the reverse function of the transmission? thats what I'm thinking. Something was leaking, I know that. And yes, Mr. Biggs, you are right there is no pressure in the trans, if there was the filler cap would blow right off of there!
studegary
06-24-2005, 02:05 PM
Now you are really getting confused. This has nothing to do with "engine oil." The pressure to activate reverse is by transmission fluid. Maybe you are misled by the term "leak." This does not mean an external leak or any loss of transmission fluid. This is a leak internal to the transmission valve body that results in insufficient pressure to activate the reverse function.
borninthe50s
06-26-2005, 11:43 PM
Hey, I can't help the confusion! I have an old transmission, valuable or not, worthy of rebuilding or not--- just sitting in my basement.
Also of note:
four manuals which point to autos once having been owned by my family:
1952 Studebaker Land Cruiser
serial no 8257490
engine no 527772
body no 34-Y5 12470
1950 Studebaker Commander
1947 Studebaker Commander
and just to throw it in, though not a Studebaker:
1941 Packard one-ten deluxe model 1900 (this manual is just about shot)
happy motoring!
studeclunker
06-27-2005, 08:28 AM
You know, just the manuals are valuable in themselves. perhaps not a great monetary value but asthetic. There may be someone who has those models of cars and might be interested in them.
Lotsa Larks!
Studeclunker
A.K.A: out2lunch
06-30-2005, 11:11 AM
At this point, the manuals are worth considerably more than the tranny.
borninthe50s
07-02-2005, 06:32 PM
Thank you, Mr. Biggs. If I choose to sell the manuals, I'll be sure to ask at least 50 cents for each:D! For you, I'll make a special deal;).
