View Full Version : Spark plug wires
wayne
06-09-2005, 04:39 PM
I have a 1951 Commander that is still running 6 volt system and I want to replace the spark plug wires. Is there any advantage in keeping the solid copper wire over the newer type? I have installed a musical horn that works fine until I start the engine then I get alot of interference . I am running horn off of 2 6volt lantern batterys hooked in series so there is no conection to the charging system and I know the spark plug wires are bad.
N8N
06-09-2005, 06:03 PM
Brian Scott makes a nice set of V-8 wires; check with JDP or Ray Fichthorn, I know those two sell them. Perhaps some other vendors as well (SASCO?)
62 Daytona hardtop
wayne
06-09-2005, 09:07 PM
I appreciate the input but I was wondering if there has been someone who has used the modern wire as oppossed to copper wire and pro & con of both. I can get both but not sure witch way yo go.
06-09-2005, 09:22 PM
Go with the modern wires. There's no real advantage to the copper ones unless you just like static in your radio.[xx(]
wayne
06-09-2005, 10:36 PM
Thank you very much. I have entered the Newport hill climb the last 3 years and have done well and I was not sure how well the new style wires work on the older cars.
