View Full Version : Checking Auto Trans Fluid
curt
06-05-2005, 09:07 AM
Is the proper way to check the fluid in an automatic to warm the car up, then while stopped shift through the gears, place the car in 'P' , with the engine still running check the dip stick? I have never know other automatic transmissons to have a different sequence of events before pulling out the dip stick. But then I have never had a Studebaker.
MarkC
06-05-2005, 10:55 AM
Curt, the fluid level in the Flightomatics is checked with the transmission in "D". Do the things you mentioned, but then make sure the parking brake is applied and/or the car is adequately blocked, then do your check. (Service manual reference, Group IV, page 37.)
Good luck.
Mark
MarkC, 64 Y8
Working in Spokane, WA
curt
06-05-2005, 12:18 PM
Good luck.
Mark
MarkC, 64 Y8
Mark,
Thank you for the information. I do know Dextron seems to be the fluid of choice from a previous question I posted.
curt
06-06-2005, 08:23 PM
I ckecked the fluid tonight, about 1/8 th of an inch below the full mark. I noticed the dipstick says 'D' on it. Man, that dip stick is heavy.
buckeye
06-07-2005, 08:57 PM
I have a 62 Champ w/AT that is checked with a dip stick through the passenger floor. What is the correct way to check the level?
jcstude
06-08-2005, 01:44 PM
Buckeye, the check procedure is the same regardless of the location of the dip stick. Install wheel chocks, engage parking brake, open access cover, warm up engine until it idles normally (off choke), cycle through gears, place gear selector in "D", check fluid level on dip stick, add as necessary.
Lew in Escondido, CA
buckeye
06-09-2005, 10:33 PM
Thanks JCStude.
len
06-10-2005, 09:21 AM
According to shop manual for my 55 with a DG250 trans. you check fluid level hot and in lo.
jcstude
06-10-2005, 12:09 PM
Len, I'm sure you are right. I was thinking of the Flight-o-Matic which is what should be in a 62. Thanks for keeping us honest!!
rockne10
06-10-2005, 07:03 PM
The manual for my 51 and 53 DG200 also says to check in low gear. It's pretty easy to pull the dipstick from the trans tunnel with your foot on the brake if you don't trust your parking brake.
curt
06-10-2005, 08:21 PM
Where do I find the DG200 name tag or the Flightomatic tag? My point is how do I know which automatic transmission I have? It is a later 1955 president because the windshield is wraparound.[?][?][?]:):):):)
JDP
06-10-2005, 08:48 PM
You should have a DG 250, tag is on the side of the case.
64 R2 4 speed Challenger (Plain Wrapper)
63 R2 4 speed GT Hawk
55 Speedster
50 2R 10 truck
