View Full Version : Tranny Rebuild?
PalmerGA
06-03-2005, 04:09 PM
Hi folks! Next project of significance for my 63 Daytona Convertible is a possible transmission or rearend (or both) rebuild. I have a terrible CLUNK! eminating from under my car (seemingly towards the rear), on occasion, when starting to move - especially after shifting from first to reverse (or vice-versa). I have a 3-on-the-tree w/ OD transmission. What do y'all suspect is the problem/cure? Is it rebuild time?
I very handy with hand tools, though I only have the basics. If it's just taking apart and replacing new gears, etc., I'm quite sure I could do it myself. I have a basic understanding of how this car operates (except the OD) and have the full shop manual. Think I can do it myself, or should I seek a professional? (There are some Studebaker enthusiasts in a town not too far from here).
'63 Daytona Convertible
06-03-2005, 07:00 PM
Sounds to me, like a bad U-joint! I'd be checkin' it out before I drove it much farther.[}:)]
Of course, with that X-member that your ragtop has, I don't think the driveshaft can drop out altogether when one of the joints lets go.[xx(]
And too - you could have a sloppy pinion gear in the rear end. But tis all just speculation until you get it up in the air and investigate.;)
Tom B
06-03-2005, 07:31 PM
The first, easiest thing to do, take off both rear hubcaps and look for red rust under the hub nut washer. If the axle/hub key is starting to wear, and the torque on the nut is below standard, (greater than 180 lbs.) the hub could be clunking on the key.
Even without rust, check the torque on these nuts.
Tom Bredehoft
'53 Commander Coupe
'60 Lark VI
Chris Pile
I agree - check the U-joints, which is a reasonably easy fix. If the rear end is out of whack, wouldn't it whine when slowing down in gear (not coasting).
06-03-2005, 08:45 PM
You'd THINK it would whine if it was worn, but some folks aren't attuned to such. I also like Tom Bredehoft's assessment of the axle nut being loose.
In tearing into this 58 wagon I just got, I found both axle nuts not torqued and you could see that the hubs had been slipping a bit on the tapered shafts. Someone had applied Never-seize to the axles to insure that they could get them off easily next time!:( But the looseness hadn't been present long enough to damage anything. The keyways showed no signs of being battered so I cleaned everything up and reassembled it after replacing the wheel cylinders and greasing the rear wheel bearings.;)
PalmerGA
06-04-2005, 02:39 PM
Great advice, as usual. I'll start off with the easy stuff, though I don't think it's as simple as a universal joint. I'll let y'all know.
n/a
06-04-2005, 03:39 PM
I'd say loose rear-emd gear mesh. My lark did that.
Kent
n/a
06-04-2005, 03:40 PM
Ooops sloppy typing, I mean Rear-end (rear axle)
Kent
06-04-2005, 06:08 PM
Kent, If you make a typo, YOU can correct it by clicking on the little icon at the top of your post - where it shows a little pencil. It lets you edit it and post the changes. I use it on occassion after I post something and see a goof or think of something to add to what I've already said.;)
n/a
06-04-2005, 10:27 PM
Thanks for the lesson on how to use the fourm....
Kent
