View Full Version : oil filter
curt
05-31-2005, 10:47 PM
I put the oil filter on tonight. I bent the high pressure line out of brake line tubing. It does not leak on a three minute run. Thanks for the advice, I did use the restricted elbo. Next is to remove a PCV valve that has replaced the vent tube. Any advice on that project?
N8N
05-31-2005, 10:51 PM
good stuff on the filter. glad to hear it worked out.
not to be a smartass but why do you want to remove the PCV valve? My advice is: if it ain't broke don't fix it.
Seriously, we will never come to perfect agreement here on which is better; but in use where a car sees a lot of idling (like around here, where there's lots of stop and go) a PCV valve keeps working when a car is standing still whereas a road draft tube does not. Therefore at least for me, the PCV is likely to keep my oil cleaner longer.
62 Daytona hardtop
curt
06-01-2005, 08:11 AM
I just want to clean it up, no way do I want a change back to the breather pipe, or go in a negative direction.:)
N8N
06-01-2005, 08:43 AM
Ah, I understand then... well just remove the PCV valve and spray some carb cleaner through it, that's really all there is to it... no magic involved...
62 Daytona hardtop
curt
06-01-2005, 09:48 PM
My PCV valve is screwed in and tight, It will just remain where it is and in its 'natural' state.
Transtar56
06-02-2005, 11:50 AM
Is there a special PCV valve for the Stude V-8?
Im not running one right now but I need to get one.
06-02-2005, 12:13 PM
There's actualy a couple different styles of PCV valves for the Stude V8. Finding one is the problem. Finding an original that is. There's gotta be some for Brand X engines that'll do the job.;)
jcstude
06-02-2005, 03:30 PM
Bob, I have some PCVs that supposedly are correct. Never had my car judged since its a 57 Hawk with a 62 Lark 259 and Edelbrock AFB clone so can't vouch for correctness but it does appear to work OK. I will look for my stash and send you one, FREE if you give me your address. I think I have 5 or 6.
Lew in Escondido, CA
curt
06-02-2005, 10:10 PM
Lew in Escondido, I try to get your email address all I get is, Error you must log in. It will not let me log in to your addrerss or anyones for that matter.
Transtar56
06-03-2005, 06:05 AM
Thanks Lew,I was just going to my local FLAPS and pick one that looked like it would work,Ill send you my address by E-mail
jcstude
06-09-2005, 12:22 PM
OK, for those who want it, my address is:
Lew Goen
PO Box 460190
Escondido, CA 92046
email: lmgoen@aol.com or lewis.goen@navy.mil
