View Full Version : transmission fluid and crank/oil
curt
05-09-2005, 08:38 PM
I just purchased a 1955 President. What are the oil needs,transmission, rearend, crank case, etc. What is the point gap? Where does one get a service book?:)
JDP
05-09-2005, 11:00 PM
Get the shop manual here:
Studebaker Autoparts Sales Co.
P.O. Box 0719 South Bend, Indiana 46624
219-287-3381 800-722-4295 FAX 219-287-3386
I use any good detergent oil, I prefer 30 weight diesel blend. Automatic transmission, use Dextron or type F, manual and rear uses 90-140 gear oil.
64 Challenger (Green Wrapper)
63 R2 4 speed GT Hawk
55 Speedster
50 2R 10 truck
N8N
05-10-2005, 09:42 AM
I have used Redline Heavy Shockproof gear oil in my rear on Ted Harbit's recommendation. I believe that he also uses it in his 4-speed, but I used Redline MT-90 because I bought the gear oil before talking to him. MT-90 probably provides better shift quality at the expense of ultimate shock load protection.
Since you have a President, you probably have either a 3-speed/OD or a DG-250. The DG will be happy on either Dexron or Type F as JDP says (Type F will give you firmer shifts,) for the 3/OD I can't offer a recommendation, the MT-90 probably doesn't have the right friction characteristics for the OD. I believe a GL-1 was actually the factory fill.
62 Daytona hardtop
curt
05-10-2005, 07:07 PM
How does one know what is in, Dextron,or Ford. THey Can't mix??.[?]
N8N
05-10-2005, 07:38 PM
They can mix just fine, they are similar formulas just have different friction characteristics (Type F helps the bands "grab" a little better)
62 Daytona hardtop
curt
05-12-2005, 08:34 PM
Thanks for the answer, they mix with different fricton abilities.
